[GA503QM] Bluetooth connection is unstable
ThanhND
I have just bought Zephyrus G15 - GA503QM.
It seems that the Bluetooth connection is unstable. Sometime, the Bluetooth is disappeared. (Cannot find the icon on taskbar, cannot add / use Bluetooth devices)
- When I check the HW in Device Manager, the Bluetooth was shut downed due to unknown issue.
--> I must disable and enable the Bluetooth device to make it work again.
For more information of my system:
- Bios version is the latest version 404
- Device driver version is the latest version
So, I would like to ask your support for this issue.
0 REPLIES 0
