Results 1 to 3 of 3
    ROG Member Array
    Feb 2019
    8
    x570 Dark Hero, 5950x, G.Skill DDR3600 help needed - No post using XMP
    Hey all,
    After reading a number of posts I need to get some help.
    Setup:
    AMD 5950x
    Asus ROG X570 Dark Hero
    G.Skill DDR43600 (4x8Gb sticks) F4-3600C16Q-32GTZN (QVL list)
    Asus ROG 3090 OC
    Corsair 1000RM PSU
    I cant seem to boot using all default settings and XMP (DOCP) enabled.
    Sometime I do, but then the system is super unstable.
    Anyone else out there running a similar setup that got it working? Would love to hear from you.
    EDIT: FWIW, I've been testing with 4x8Gb kit of G.Skill DRR4 3000 over the last couple of days and that seems to work with XMP.
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    170
    2,216
    Hello,
    What is the Q-CODE displayed?
    If the system is sometimes able to pass POST then the stability is borderline. Try increasing SOC voltage if not having done so already.
    ROG Member Array
    Feb 2019
    8
    So I tested with the DDR3000 the last two days and this evening ended up getting WHEA errors twice in a row for different APICs.Â*
    Coincidentally a second 5950 CPU arrived to test with, and I swapped it out, and added back the DDR3600. I set BIOS to default, enabled DOCP (XMP) and booted successfully. As I didnt have a lot of time, I joined some friends for Warzone as a quick bench, played a couple of matches and then when we eventually quit the game my system lost display signal and rebooted. I could only find a critical error for the reboot, and a couple of ACPI warning errors in event viewer for the crash. No WHEA errors. I’ll try upping SOC as suggested tomorrow, but getting a bit frustrated tbh.Â*
