Results 1 to 8 of 8
05-21-2021 06:29 PM #1
- Join Date
- May 2021
- Reputation
- 10
- Posts
- 10
Unestable or low FPS with a TUF F15 FX516PM-211 RTX 3060
I Recently bought a brand new Asus Tuf Dash F15 with 11th gen i7 11370h, RTX 3060, 16gb ram 3200hz and 1080p 144hz display.
I've been testing it for a few days and find out that it has a terrible FPS while gaming when I'm using the dedicated nVidia GPU. Games like League of Legends, Valorant, CSGO, can't hold 144 fps and drops down to around 100 fps, and it's very noticeable while game sesions, even worse with the First Person Shooter games. It's pretty funny that those are not very demanding game and the RTX 3060 can barely hold a decent FPS.
The funny part of this is that, no matter which graphics settings I set (LOW, MEDIUM or HIGH, or 720p or 1080p resolution), it does 144 fps for a little while then the FPS drops.
My previous laptop (XPG XENIA) did a pretty solid 144 fps with only 2 or 3 frames drops (in some few situations) with a 9th gen i7, 144hz panel and a GTX 1660ti with the same games and same game's graphic settings, but it could do a solid 144fps.
- I always use a fanless laptop cooling pad , those that do not interfere laptop fans and elevate the laptop over the surface.
- Windows, drivers, bios and ARMOURY CRATE app are up to date (i'm checking everyday if there are new updates)
-Armoury Crate is set to Turbo mode with iGPU disabled. Also tried with Performance Mode.
- nVidia RTX 3060 is set as primary Graphic Card in nVidia settings
- AC is connected all time.
- Temps is always around 70-75° celcius
I noticed that Armoury Crate app shows the GPU never hits 100% of usage (around 60 - 70%) and the CPU is at 100% but it doesn't go any further than 4400hz (Asus claims that the i7 11370H can do 4,8ghz).
Testing in more demanding game like Horizon Zero dawn, My previous laptop could do 55 - 59FPS in Ultra settings and with this laptop is barely doing above 45fps.
i'm pretty concern why a GTX 1660ti and a 9th gen Intel i7 do a better performance than 11th gen Intel i7 wih a RTX 3060? This laptop has two generation newer hardware and it performs worse.
Is there something that i'm missing to check?Last edited by Maurarg; 05-21-2021 at 07:50 PM.
05-21-2021 09:31 PM #2
Triton.se PC Specs Laptop (Model) Asus ROG Strix G17 G713QR-HG022T Motherboard G713QR Processor AMD Ryzen 9 5900HX Memory (part number) G.Skill RipJaws 3200MHz CL 22 1.2v 2x16GB Graphics Card #1 NVIDIA RTX 3070 115+15W Monitor Acer XV272UV 2560x1440 170Hz HDR400 (USB-C DP 1.4) Storage #1 1 TB NVMe original SK Hynix Storage #2 1 TB NVMe Kingston KC2500 Power Supply 240W power-brick Keyboard Corsair K55 RGB Mouse Deltaco DM210 Mouse Pad Steelseries Small Headset/Speakers AKG K530
- Join Date
- Apr 2021
- Reputation
- 10
- Posts
- 85
In Armoury Crate home, select GPU tab and set GPU Power Saver to Advanced and apply changes. If you have same problems as many others, that will be a fix (GPU runs in proper way, not like in a battery mode way with STRONGLY REDUCED CLOCKS while still on AC power)
I wonder why mods aren't here first to help....
05-22-2021 12:23 AM #3
- Join Date
- May 2021
- Reputation
- 10
- Posts
- 10
05-22-2021 05:24 AM #4
- Join Date
- Apr 2021
- Reputation
- 10
- Posts
- 85
05-24-2021 07:19 AM #5
- Join Date
- Feb 2019
- Reputation
- 15
- Posts
- 920
Hello Maurarg,
I'm sorry that the TUF series does not have manual mode.
Please share the full screenshot of Armoury crate when you are playing games,
And the software you use to detect the fps.
05-24-2021 07:22 AM #6
- Join Date
- Feb 2019
- Reputation
- 15
- Posts
- 920
05-25-2021 06:00 PM #7
- Join Date
- May 2021
- Reputation
- 10
- Posts
- 10
05-30-2021 06:16 PM #8
- Join Date
- May 2021
- Reputation
- 10
- Posts
- 10
I've recently updated to the lastest BIOS version 316 for my laptop model and unfortunately it's performing worse than before.
I saw no change in Horizon Zero Dawn, it going 40 ish fps but in League Of Legends I used to play around 100 ish fps (as the lowest amount of fps) but now it's droping down to 90 fps. Same performance's drop happened in Cyberpunk 2077, FPS was around 40 and 50 (with DLSS) with mixed graphics settings, and now is going around 20-30 FPS.
One more thing: Mousepad lag bug is happening again. It was fixed in Bios 314 but now with 316 version is happening again.
To be honest, I feel like I bought a downgrade rather than an upgrade with this laptop.Last edited by Maurarg; 05-30-2021 at 06:28 PM.
