Results 1 to 6 of 6
    ROG Enthusiast Array spooks PC Specs
    spooks PC Specs
    MotherboardRASUS® ROG STRIX Z270E GAMING: LG1151, USB 3.1, SATA 6GB,
    ProcessorIntel® Core™i7 Quad Core Processor i7-7700k (4.2GHz) 8MB Cache
    Memory (part number)32GB Corsair VENGEANCE DDR4 3200MHz
    Graphics Card #1Palit 8GB NVIDIA GEFORCE GTX 1080
    Sound CardONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO
    MonitorSony KD-43XE7073 4k tv
    Storage #1samsung 850 evo ssd 500GB
    Storage #2500GB WD 3.5" HDD, SATA III
    CPU CoolerCorsair H100i V2 Hydro Cooler w/ PCS Liquid Series Ultra Quiet Fans
    CaseCORSAIR GRAPHITE SERIES™ 780T
    Power SupplyCORSAIR 750W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
    Keyboard Gaming Keyboard G910
    Mouse G700s Rechargeable Gaming Mouse
    Headset/Speakers Logitech G633 Gaming Headset
    OS windows 10 Pro
    spooks's Avatar
    Dec 2017
    38
    USB-C to HDMI Adapter
    Hi I’m not sure if this is the right forum for my question ? I have a Rog Strix Z270E Gaming motherboard and a GTX 1080 GPU which is plugged into my hdmi Tv . The Z270E has a usb type-C at the back and I was wondering is there a way to connect my TV via the usb type-C connection rather than the hdmi connection on my gpu which is connected to the hdmi TV . I see you can get usb-C to hdmi adapters and wondered if that would work ? and would it improve the graphics
    ROG Guru: White Belt Array DjRavix PC Specs
    DjRavix PC Specs
    MotherboardAsus Maximus XIII Extreme
    ProcessorIntel i9 11900K
    Memory (part number)Corsair Dominater Platinum RGB (c
    Sound CardFocusrite Scarlett 18i8 MK2
    MonitorSamsung SyncMaster S22B350 (X2)
    Storage #1Samsung 980 Pro
    CPU CoolerEK Velocity
    CasePhanteks Enthoo Primo
    Power SupplyCorsair AX1200i
    Keyboard Logitech K800
    Mouse Logitech MX Master 3
    Mouse Pad Steelseries
    Headset/Speakers KRK RP8
    OS Windows 10 Pro
    Network RouterFritzbox
    Accessory #1 Native instruments Kontol S61 MK2
    Apr 2014
    31
    75
    Quote Originally Posted by spooks View Post
    uhm ... If it's a Thunderbolt port it will probably work but this is also dependent on the CPU
    it also depends on what you mean by "improve the graphics" ...
    Better image Quality, Maybe ...
    Better Performance, No it will be worse ... since it will use the CPU's build in GPU
    ASUS Maximus 13 Extreme
    Intel i9 11900K
    Samsung 980 Pro 1TB
    2 X Samsung 980 Pro 2TB
    Corsair AX1200I
    EK-Velocity D-RGB - Nickel + Plexi
    EK-XTOP Revo Dual D5 PWM Serial - (incl. 2x pump)
    XSPC RX480 + XSPC RS280
    4 X Corsair SP120 PWM OEM Fans
    2 X Noctua NF-A14 industrialPPC-2000 IP67 PWM
    2 X Noctua NF-A14 PWM chromax.black.swap
    2 X Noctua NF-S12A PWM chromax.black.swap
    1 X Noctua NF-A15 HS-PWM chromax.black.swap
    spooks PC Specs
    OS windows 10 Pro
    spooks's Avatar
    Dec 2017
    38
    ok thanks for the advice i've got a i7 7700k cpu could i upgrade my Z270E MB with a Thunderbolt 3 PCIe Card
    DjRavix PC Specs
    OS Windows 10 Pro
    Apr 2014
    31
    75
    if the board has a Thunderbolt header it is possible but then you need to use the included Display port cables to go from your GPU to the Thunderbolt card
    Intel i9 11900K
    Samsung 980 Pro 1TB
    Corsair AX1200I
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    344
    8,018
    Any picture quality issues are probably due to limitations of your TV. HDMI output from PCs generally exceeds the capabilities of most TVs in terms of resolution and refresh rate so changing to a different output is very unlikely to improve anything.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    spooks PC Specs
    OS windows 10 Pro
    spooks's Avatar
    Dec 2017
    38
    thanks for that
