Results 1 to 3 of 3
    ROG Guru: Orange Belt Array rjbarker PC Specs
    rjbarker PC Specs
    MotherboardMaximus XI Extreme (BIOS 1503 to 1903)
    Processor9900K @ 5.1 Ghz w EK Velocity
    Memory (part number)32 GB -Dominator Platinum 3200 Mhz CAS 16
    Graphics Card #1Evga RTX 3080Ti FTW3 Ultra w FC EKWB
    Sound CardOnboard Realtek
    MonitorDell Alienware 34" Ultra wide 120Hz Gsync
    Storage #1Samsung 970 Pro 512G M.2 NNMe
    Storage #2Samsung 860 Pro 512G & 256G
    CPU CoolerEK Supremacy Copper w Nickel Plating
    CaseCorsair 900D
    Power SupplyCorsair AX 1600i
    OS W10 HP x64 - 21H1
    Accessory #1 480 * 360 * 240 XSPC Radiators (15 Fans) w 4 Channel 200W Fan Controller
    Accessory #2 XSPC Photon Rez / Vario Pump combo
    Accessory #3 Fesser Flex Tubing - Bits Power Fittings & EK SLi Terminal
    rjbarker's Avatar
    May 2013
    37
    307
    Maximus XI Extreme - 3080 FTW3 Ultra - 9900k 5.1 Ghz - Custom Loop
    Received my Evga 3080FTW3 Ultra with EK Quantum Vector and Nickel backplate...re-built Vega Build swapping out 2 x 1080Ti's....
    The 9900k all core 5.1 Ghz w EK Vector / 1.37v Adaptive / GPU +140 / + 625 Boost 2085 - 2100 Mhz...
    And of course Asus Motherboards have been my "go to" since Rampage IV Extreme X79......
    This Maximus XI Extreme has been awesome..(pretty painless OC'ing 9900k all cores to 5.1 Ghz)....I would have gone with an Asus Strix 3080 OC but took the first 3080 that I could get my mitts on.
    May see if I can get a Strix 3080Ti when available!!!
    Custom Loop single D5 Vario pump w XSPC Rez....mix of XSPC RX/EX Radiators (480 * 360 * 240)..all Bits Power fittings...16 Fans all running on a 4 Channel - 50w per channel Fan Controller.
    Check out "rjbarker PC Specs" for a complete list.....!
    Cheers n thanks for stopping by!!
    ROG Guru: White Belt Array AS185 PC Specs
    AS185 PC Specs
    Laptop (Model)Lenovo Y700-17ISK
    MotherboardZenith Extreme
    ProcessorAMD 1950X
    Memory (part number)8 x G Skill F4-3200C16D-32GTZKW @ 2666MHz
    Graphics Card #1Nvidia Titan RTX
    Sound CardIntegrated SupremeFX
    MonitorSamsung Odyssey G5 C34
    Storage #16 x PNY 2TB XLR8 CS3030
    Storage #23 x 1TB Crucial MX500
    CPU CoolerThermaltake Water3.0 Ultimate
    CaseCorsair Obsidian 900D
    Power SupplyCooler Master MasterWatt Maker 1200W
    Keyboard Razer Ornata Chroma
    Mouse Razer Mambe TE / Logitech USB TrackMan Wheel
    Mouse Pad steelseries Cyberpunk 2077 edition
    Headset/Speakers Logitech Z-5300e
    OS Windows 10 Home x64
    Accessory #1 Asus Hyper M.2 X16 Card V2
    Accessory #2 Asus DIMM.2 card in slot
    Accessory #3 KingMod Corsair 900D Silencing Kit
    AS185's Avatar
    Feb 2020
    21
    107
    Excellent setup. I like the colors
    rjbarker PC Specs
    CaseCorsair 900D
    rjbarker's Avatar
    May 2013
    37
    307
    Quote Originally Posted by AS185 View Post
    Thanks.....could be considered either Seattle Seahawks or Vancouver Canucks theme colors
