Results 1 to 9 of 9
Thread: rebar disabled
    ROG Guru: Black Belt Array Hopper64 PC Specs
    Hopper64 PC Specs
    MotherboardAsus M13EG Bios 1007
    Processori9 11900K @ 5.2 1.50 VCore
    Memory (part number)GSkill F4-3600C16D-32GTRS
    Graphics Card #1Asus 3090 Strix OC/Optimus Block
    Sound CardCreative SB X4
    MonitorAsus ROG XG349C
    Storage #1Samsung 980 Pro
    CPU CoolerQuantum Kinetic TBE 300 D5 with Quantum VTX 160
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1600i
    Keyboard Asus ROG Claymore 2
    Mouse Asus ROG Gladius III
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,360
    rebar disabled
    Running an Asus R6E Encore X299 on a test bench with the latest 1004 bios that supports rebar. Just installed an Asus 3080 strix OC. Looks like the latest bios shipped with this video card (see pic). Running latest Nvidia driver. Can't figure out why rebar is not enabled. ?? Ideas?? Thanks.
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    190
    2,424
    Hi Hopper,
    What's the status say in the top right in UEFI? Should be able to toggle it there.
    Hopper64 PC Specs
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,360
    It says ON in the bios. Can’t figure this one out at all. ???
    Mar 2016
    190
    2,424
    Not that it should make much difference, but are you using a PCIE riser or is the card connected directly?
    Check in the UEFI that 4G decoding is enabled. Although the toggle on the landing page should already do this for you.
    Hopper64 PC Specs
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,360
    It's connected directly.
    I might disable rebar in the bios, reboot into windows, reboot again and reenable rebar in the bios and see if that does it. I don't know otherwise.
    Hopper64 PC Specs
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,360
    Yea. Still no change. Have no idea why rebar is not working. OS updated, MB Bios updated and rebar was working with another graphics card, Vbios appears to be the latest. ????
  7. #7
    Hopper64 PC Specs
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,360
    Just tried V5 of the bios update just to see if it would work. Didn't work yesterday. Well, it updated something because rebar is enabled now. I had updated the OS to 21h1 today and right clicked on the exe, run as administrator. Bios version is no different.
  8. #8
    Mar 2016
    190
    2,424
    Who knows, it's possible something was stuck at driver level or was tripping GPUZ into think it wasn't enabled. Glad you got it working!
  9. #9
    Hopper64 PC Specs
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,360
    Thanks. GPU-Z was likely correct since it was disabled in the Nvidia CP too.
