NEW ASMEDIA Firmware Bring ASMEDIA 3142 to USB 3.2 Speed
restsugavan
88781
ASMEDIA 3142/2142 USB Controller Firmware 191209_70_F2_18 Bring USB 3.2 20Gbps speed support
88782
ASUS ROG RAMPAGE VI EXTREME and X299 coming with Firmware 170308_70_02 Featuring USB 3.1 10Gbps speed.
88783
After easy process you can update ASMEDIA 3142/2142 USB Controller via Firmware 191209_70_F2_18 above
88784
Enjoy new 20Gbps speed on your RIG.
For more info
https://www.station-drivers.com/index.php/fr-ca/articles/3084-asmedia-asm-3142-asm-2142-usb-3-2-cont...
W11CANARY 26200.5001 Core i9 7980XE 02007108 MCE ME 11.12.95.2499 R6E Modified BIOS 3801 SAMSUNG OG9 FW 1019.0 SSD 970 EVO PLUS 1 TB x 3 NVIDIA RTX 4090 GAME READY 552.22 64GB GSKILL DDR4 3200MHz JBL 9.1 Sound Bar DTS-X
15 REPLIES 15
PanosXidis24
Level 11
i have one error the first is pass the second fail but ok!!!
MarcioTB
Worked fine thanks!
Does need to update drivers too? On devices still appear Asmedia USB 3.1!
MirceaForce
For more info
Will this be supported on asus rampage vi extreme omega ?
IT will update all the usb ports to 3.2 ? or only the ones that are 2 x USB 3.1 Gen 2 port(s) (2 at back panel, , 1 x Type-A+1 x Type-C) ?
MB: ASUS RAMPAGE VI EXTREME-CPU: Intel Core i9-7920X Processor Extreme Edition 4.2 GHZ auto-CORSAIR Hydro Series H80i v2 Video: GEFORCE GTX 1070 Founders Edition. - G.SKILL 32GB 14-14-14-34
F4-3200C14Q-32GTZR- Seasonic PRIME Titanium 850 w-SSD: Samsung SSD 850 PRO 2TB x3 -SSD: Samsung 950 PRO M.2 512GB OS-Sound Blaster Z -Intel Ethernet Server Adapter I210 CASE:Cooler Master: HAF X MONITOR:IPS LED LG 27" 27UD69P 27 inch 4K 5 ms TV: LG OLED55C8P OS: Windows 10 x64 Pro up to date
Mine is Omega and update worked!
Seems to be all Asmedia ports
Desertum_0
Dear restsugavan,
Does this apply to the Rampage Encore?
Thanks for your advice mate.
Desertum_0 wrote:
Dear restsugavan,
Worked fine on my Encore.
I just flashed it without any issues however which USB hub is the one that i just updated?
