Control 12v RGB and 5v ARGB with one controller?
xmanrigger
Level 12
I have a Rampage IV Formula system I am rebuilding. There is no ARGB/RGB controller onboard. Is it possible to control 12v RGB and 5v ARGB with one controller so everything is in sync?
This is what I need to control:
- 9X Thermaltake Pure12 ARGB SYNC Fans (5v)
- 1X HEATKILLER® IV for RTX 2080 - ACRYL Ni-Bl RGB (non- ti) (12v)
- 1X EK-Quantum Kinetic TBE 300 D5 PWM D-RGB - Acetal (12v)
GUTS: ROG Strix Z490-A / i9-10850 / 16GB G.Skill TridentZ Royal 4000mhz / WD Black 1TB M.2 - 2TB Ki...
WATER: EK Velocity Strike - CPU / EK-Quantum Vector - GPU / 2X Alphacool NexXxoS UT60 360 Radiators / XSPC Photon Rez / D5 Pump / DISTILLED WATER + Silver Coil
SmokeyKilla wrote:
https://www.amazon.com.au/EZDIY-FAB-Converter-Transfer-Splitter-Motherboard/dp/B082KJH2T3 you need something like this and a cable to suit all your fans
https://www.amazon.com.au/Cooler-Master-Addressable-Universal-Radiators/dp/B083X1W5G4/ref=pd_sbs_1/3...
Hey Smokey, thanks for the reply. The motherboard has no 5V or 12V onboard RGB/ARGB headers. The controller you linked to sounds as though it is only a converter . The diagrams only indicate 3-pin, 5V output. I need a single stand-alone controller that will control both 12V RGB and 5V ARGB/DRGB. Motherboards can do it (ASUS Z490 Strix), so I would have to think there are stand-alone controllers on the market that can as well. If not, somebody best jump on it now and make some money.
This controller will do it provided you have a spare fan header doesnt have to be RGB
