Results 1 to 1 of 1
    ROG Member Array gb2048 PC Specs
    gb2048 PC Specs
    MotherboardROG STRIX z390-E
    ProcessorIntel i5-9500
    Graphics Card #1ROG STRIX GeForce GTX 1660S OC 6G
    CPU CoolerbeQuiet Dark Rock Slim
    CaseNZXT H510
    Power SupplybeQuiet Straight Power 11 550W
    OS Windows 10 64-Bit 21H1
    gb2048's Avatar
    Aug 2019
    16
    GPU MHz clock speed overspeed
    Since updating to Win 10 21H1 build 19043.1023, I've noticed that the GPU clock speed (in GPU Tweak II) and then in GPU Tweak III in the monitor was 90 / 100 MHz more than the maximum set at, and that the card was heating up faster / running hotter as the fans were faster than normal. I don't know what is going on, but thought I should post as perhaps this could be a serious issue. Image attached whilst running Train Sim World 2 - you can see the disparity. Note: Armory crate is up to date, but the UI does not work due to a broken MS Store with 'The parameter is incorrect' type messages that I cannot seem to fix, despite best efforts.
    I've created some custom profiles to get the speed desired.
Tags for this Thread
