Results 1 to 3 of 3
    ROG Guru: White Belt Array AliAPCMR PC Specs
    AliAPCMR PC Specs
    MotherboardZ390 E
    Processori7 9700k
    Memory (part number)Corsair RGB Vengeance (Corsair CMR16GX4M2A2666C16)
    Graphics Card #1GTX 1070 EVGA FTW
    Sound CardAsus SupremeFX
    MonitorSamsung 1080p 40inch 3D Tv
    Storage #1Samsung Evo 500gb SSD
    Storage #22 1TB Samsung QVO SSD
    CPU CoolerNoctua DH15
    CasePhanteks Evolve X
    Power Supply850 wats EVGA SUPERNOVA
    Keyboard Corsair Raptor K55 rgb
    Mouse Corsair Harpoon RGB
    Headset Razer kraken tournament edition
    Mouse Pad Corsair
    OS Windows 10 (Latest Update)
    Accessory #1 NZXT GRID V2
    AliAPCMR's Avatar
    Sep 2017
    21
    77
    Sonic Studio 3 not working
    Hi guys i have a issue where, completely out of random when i open SS3 i get this error message:
    "The Current System is not supported, or the audio driver has not been properly installed"
    I know the software works because i never had a issue before, if i restart Nahimic service the app works fine until that message re appears, or if i re install SS3 then the app works again untill the error re appears or if i re install the audio drivers and again issue re occurs, its annoying because i use this software.
    ROG Guru: White Belt Array Bushmaster78FS PC Specs
    MotherboardASUS® ROG™ STRIX Z370-G Gaming (Wi-Fi AC)
    ProcessorIntel® Core™ i7-8700K Processor
    Memory (part number)Corsair DOMINATOR® PLATINUM Special Edition Torque 32GB
    Graphics Card #1ASUS® ROG™ STRIX GeForce RTX™ 2070 OC Edition 8GB
    Sound CardASUS® ROG™ SupremeFX 8-Channel High-Definition Audio CODEC S1220A (on-board)
    MonitorASUS® ROG™ Swift PG349Q Ultra-wide G-SYNC™ Gaming Monitor
    Storage #1Corsair Force Series™ MP510 480GB M.2 SSD
    Storage #2Seagate BarraCuda 500GB Internal Solid-State Drive
    CPU CoolerCorsair Hydro Series™ H55 Quiet CPU Cooler
    CaseCorsair Carbide Series™ 200R Compact ATX Case
    Power SupplyCorsair TX-M Series™ TX750M — 750-Watt 80 Plus® Gold Certified PSU
    Keyboard ASUS® ROG™ STRIX Flare
    Mouse ASUS® ROG™ Spatha
    Mouse Pad ASUS® ROG™ Strix Edge Vertical Gaming Mousepad
    Headset/Speakers Sony® SRS-D5100 5.1 Multimedia and Gaming Speaker System
    OS Windows 11 Pro
    Network RouterNETGEAR® Nighthawk® 5-Stream AX4200 Wi-Fi 6 Router (RAX43)
    Accessory #1 Meta Oculus Rift VR
    Accessory #2 ASUS® BW-16D1HT Blu-ray Writer
    Accessory #3 Thermaltake® Commander FT Touchscreen Fan Controller
    Bushmaster78FS's Avatar
    Mar 2019
    43
    87
    Quote Originally Posted by AliAPCMR View Post
    Potentially, software components are missing or corrupt.
    Did you try asking here?
    [DRIVERS] Realtek Audio (MB | Intel 2xx/3xx/4xx/5xx & AMD 3xx/4xx/5xx) (asus.com)
    AliAPCMR PC Specs
    MotherboardZ390 E
    Processori7 9700k
    Mouse Pad Corsair
    AliAPCMR's Avatar
    Sep 2017
    21
    77
    Quote Originally Posted by Bushmaster78FS View Post
    Thank you for the reply, I do not believe this is is the cause because sometimes its fine and sometimes it brings up the following message that i have show in the original post. I have re installed the OS and made sure i installed every update and driver and is up to date and the issue is still there, this happened after sonic studio 3 got updated
Tags for this Thread
