Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    ROG Member Array Zorlac01 PC Specs
    Zorlac01 PC Specs
    MotherboardZ590 Maximus HERO 13
    Processori9 11900K
    Memory (part number)Gskill 3600 CL16
    Graphics Card #1Nvidia FE 3080 TI
    Sound CardCreative X AE-5
    Monitorpredator 4K 144HZ
    Storage #1Samsung EVO plus 500G
    Storage #2Samsung Evo plus 1TB
    CPU CoolerCorsair H100i XT pro
    CaseCorsair X570
    Power SupplyCorsair AX 850
    Keyboard Razor Tartarus
    Mouse Razor Deathadder BLK edition
    Headset X blaster / Razer cans
    OS W10 pro
    Jan 2015
    17
    LAUNCH CSM a must for DP to work?
    Hero13 motherboard REQUIRES me to launch CSM in order for the display ports to work properly on new 3080 TI graphics card.
    I CANNOT get into bios without this method. The monitor shows NO SIGNAL until I'm splashed on desktop. This issue does NOT appear with HDMI. I want 120HZ and 4K, so display port for me is a must. Could this be a bios issue? CSM disabled and 2080TI worked perfectly...
    anyone? Bueller?
    thx
    ROG Member Array blukas69 PC Specs
    blukas69 PC Specs
    MotherboardMaximus Hero XIII (0402)
    Processor10900K
    Memory (part number)G.Skill Ripjaws V 32GB DDR4-3600 CL14~F4-3600C1
    Graphics Card #1GIGABYTE AORUS RTX 3080 Ti MASTER 12GB
    Sound CardMOBO
    Storage #1Firecuda 520 SSD ZP000GM30002
    Storage #2INLAND 2T
    CPU CoolerDH-15 BLACK CROMAX
    CaseASUS GT501
    Power SupplySEA SONIC 1000 PRIME TX
    OS WIN 10 PRO
    Mar 2021
    18
    I have same problem with a 3060 and same board. Cant even get back into my bios to change. No matter what I do goes right to windows splash screen. very frustrating. I get no display unless I hook up an old gtx260 then go back to my 3060 WTF been bugging me too.
    ROG Guru: Green Belt Array Saltgrass PC Specs
    Saltgrass PC Specs
    MotherboardMaximus XIII Hero
    Processori9 11900K
    Graphics Card #1EVGA RTX 3090 FTW
    Sound CardOn Board
    MonitorDell AW3420DW
    Storage #1Samsung 980 Pro 2 TB
    Storage #2Samsung 860 Pro 1 TB
    CPU CoolerCooler Master Hyper 212X
    CaseCooler Master
    Power SupplyAntec HCP Platinum 1000
    Keyboard ASUS Strix Flare
    Mouse ASUS Chakram
    Headset/Speakers Logitech wired 5.1
    OS Win 10 Pro
    Network RouterROG Rapture GT-AX11000/AXE11000
    Accessory #1 VR Headset
    Accessory #2 Saitek X52
    Jan 2014
    18
    591
    To start, your specs show a monitor at 144K.. Do you have a different one now?
    I have the 3090 and do not have to run the system with CSM disabled. Since the CSM is involved in the Secure Boot situation, the only way it might tie in is with the Video cards firmware. Has it been updated lately? Many of those cards do get updates shortly after being released..
    Does you monitor have any special capabilities, such as HDR? I will assume your Display port cable is up to the task and is not limiting in some way.
    Do you have Thunderbolt enabled in the Bios?
    The video output during boot is very basic so it should not be a problem with getting into the Bios. But maybe another monitor that had a DP connection would work.
    If this card is an EVGA also, you may want to check over at their community site.
    Edit: I also just saw this in case it might be involved
    https://www.nvidia.com/en-us/geforce...5-released-52/
    Zorlac01 PC Specs
    Processori9 11900K
    CaseCorsair X570
    OS W10 pro
    Jan 2015
    17
    Yes, SUPER frustrating, and thank you for the replies!
    My monitor CAN do 144 overclocked, but I leave it at 120hz, as it needs DUAL DP cables to reach 144. The card is Nvidia FE, brand new from retailer 3080 TI. This card has NO issues whatsoever with my 1440P predator monitor. I tried 2 new cables, no joy. I will say however, the card is fine with HDMI, but at 60hz of course.
    same scenario as Blukas, it works with DP and CSM disabled, but it ONLY splashes me to desktop before the monitor communicates with the card. I am NOT able to get into bios.
    I must restart with HDMI pugged in, go into bios, and change CSM back to enabled. I DO have thunderbolt enabled for no reason, I will try that now.
    blukas69 PC Specs
    Processor10900K
    Sound CardMOBO
    Storage #2INLAND 2T
    CaseASUS GT501
    OS WIN 10 PRO
    Mar 2021
    18
    I would try too. but cant get into Bios unless i put an old card in LoL
    Zorlac01 PC Specs
    Processori9 11900K
    CaseCorsair X570
    OS W10 pro
    Jan 2015
    17
    Plug both DP and HDMI into your monitor. HANG the HDMI near the rear of the card. If you need to get into bios, restart, unplug the DP and plug in the HDMI real fast! You'll boot into bios fine. I know it sucks, but what else can ya do? I've been up for 3 days trying to figure this out...
    OH... no joy with Thunderbolt Disabled...
  7. #7
    blukas69 PC Specs
    Processor10900K
    Sound CardMOBO
    Storage #2INLAND 2T
    CaseASUS GT501
    OS WIN 10 PRO
    Mar 2021
    18
    I ended up fixing by doing a DDU driver uninstall and a Monitor driver uninstall. Now works and can get into bios. after reinstall of GPU and monitor.
    tried with another HDMI old TV and had display for bios. So It was a combination of the two for me. Hope this helps.
  8. #8
    Feb 2019
    129
    712
    Boot -> Fast Boot: Disabled
    Boot -> Boot option #1 -> Forced to nvme drive
    Boot -> Secure Boot -> O/S Type: Windows UEFI mode
    Boot -> CSM (Compatibility Support Mode) -> Launch CSM: Disabled
    Boot -> Boot Configuration -> Option ROM Messages: Disabled
    Boot -> Boot Configuration -> Interrupt 19 Capture: Disabled
  9. #9
    Zorlac01 PC Specs
    Processori9 11900K
    CaseCorsair X570
    OS W10 pro
    Jan 2015
    17
    I really appreciate your input guys, thank you.
    I do not need to uninstall driver because I don't allow windows to install anything on a fresh W10. I also predownload the nvidia driver to flash drive, and install it before i even get online, so there are NO other drivers for conflict. Same with my monitor driver, and ALL other MAINBOARD drivers. When I'm finally ready to connect my ethernet cable, ALL drivers and bios are updated properly, as to avoid conflict.
    I have NO option to disable Option ROM message, only force bios, or Something..I forget. Anyway, tried both, no joy. Everything else you suggested Johnny, I've tried. Thank you both though... please keep the suggestions coming, as I'm ready to incinerate something...
    I'm also quite certain this isn't a driver issue, as the situation occurs PRIOR to windows load. It's either monitor, or bios. Card works perfectly fine CSM disabled on my other monitor. Oh FYI my other system is the Z590E wifi strix board with a 10900KF. if that helps.
  10. #10
    Saltgrass PC Specs
    Processori9 11900K
    Sound CardOn Board
    CaseCooler Master
    Mouse ASUS Chakram
    OS Win 10 Pro
    Jan 2014
    18
    591
    There seem to be some folks on the EVGA site having the same situation.. The OP gave their solution in one of the last posts from yesterday. You might check to see if it makes sense to you.
    https://forums.evga.com/Solved-Help-...-m3368802.aspx
