3070 KO Irregular fan speeds.
wONKEyeYEs
I have a 3070 KO with ASUS GPU Tweak II installed.
Fan and Fan 2 are set to custom curves @40% from 0C to 55C where it starts to ramp up.
The fan speed is continually changing from 0RPM to 1200RPM and anywhere in between while under 60C.
It's like the custom fan curve is fighting with the cards 0RPM setting.
Once the card gets past 60C the fan curve is followed without repetitive ramping.
Anyone have a similar problem or solution?
0 REPLIES 0
