Results 1 to 4 of 4
    ROG Member Array
    Aug 2016
    6
    5950x w/ X570 Dark Hero - weird USB Power issues
    Hey folks, like many of us - i've been experiencing rather odd USB power issues.
    Window 10 pro, latest update, etc...
    BIOS tried: 3501/3601
    Running into a rather odd issue with a Fanatec Steering wheel:
    When I initially plug it in, works fine - if i start up a game in say steam, the device disconnects (as if there is too much power draw from the port). If I exit the game, it reappears (this is 100% consistent, not a fluke).
    Also, if I have a program that draws too much power from the PCIE, it will also take the controller offline until I end that program.
    Any solutions to this? I've turned off USB power management in windows but figured there may be a BIOS setting on the C8DH boards?
    Thanks!
    ROG Guru: Brown Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 11 64bit Pro
    Network RouterPfSence Intel i5-10210U 6 Port
    Accessory #1 TP-Link Gigabit 8&6 Port Switches
    Apr 2018
    65
    1,305
    Figure out what USB you're plugging into. Is it one controlled by CPU or the motherboard and version, then see if using different ones produce same results. Might help with troubleshooting the issue.
    Stick to the latest BIOS as recent fixes have been centered around USB issues.
    ROG Member Array
    Aug 2016
    6
    Okay - so I don't know if this is a temporary work around for now but disabled all the options under device manager to allow pc to shut off device and any power management options for USB/HID devices. I am still seeing the issue but it is occurring more seldom and under only specific instances where programs are drawing all PCIE power (miners are one such program).
    ROG Enthusiast Array
    Jun 2020
    49
    Quote Originally Posted by DarkPhantom View Post
    It might be worth opening up a support ticket directly with AMD, as a few weeks ago they were looking for people like you to work on fixes for these issues.
    Â*
