Results 1 to 4 of 4
    ROG Junior Member Array tcyr123 PC Specs
    tcyr123 PC Specs
    MotherboardASUS ROG STRIX B550-I GAMING
    ProcessorAMD Ryzen 9 5900X
    Memory (part number)CMK32GX4M2D3600C18
    Graphics Card #1ASUS STRIX GTX 970
    Storage #1Samsung SSD 980 PRO 1TB
    Storage #2Samsung SSD 970 EVO Plus 500GB
    CPU CoolerCorsair iCUE H100i RGB PRO XT
    CaseFormD T1
    Power SupplyCorsair SF750
    OS Microsoft Windows 10 Home
    Feb 2014
    2
    STRIX B550-i USB-C audio no sound, not detected
    Hello people,
    This is a new PC build and I've ran into issues with the USB-C audio on the B550-i.
    After a fresh install of windows 10, The USB-C audio was working fine, I'm able to toggle between Speaker and headphones (connected to USB-C) and there are selections on the Spatial sound for DTS effects.
    A few days later, the USB-C audio stopped working completely. It does not detect anything that's plugged in and Realtek Audio Console's USB-C option is greyed out. Device manager does not show any USB-C audio devices as well.
    I've looked through this forums for possible solutions and have tried deleted and reinstalling the drivers from https://rog.asus.com/forum/showthrea...ghlight=b550-i to no avail.
    I've tried different BIOS and currently at the latest 2401, and it's not helping either.
    Hence I'm looking for assistance here, I'd appreciate any advice.
    ROG Guru: Green Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD NVMe Samsung 970 EVO Plus 500GB
    Storage #2SSD NVMe Samsung 960 EVO 250GB | SSD NVMe Corsair Force MP510 240GB | SSHD AHCI Seagate FireCuda 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Headset/Speakers Logitech Z333
    OS Windows 11 64 bit 21H2/CO/22000.x
    MoKiChU's Avatar
    Aug 2013
    329
    583
    1) Update your BIOS to the latest (2403) : https://dlcdnets.asus.com/pub/ASUS/m...-ASUS-2403.ZIP
    ROG STRIX B550-I GAMING BIOS 2403
    1. Update AMD AM4 AGESA V2 PI 1.2.0.3 Patch A
    2. Improve system stability
    2) Update your AMD Chipset Drivers from the first post of this thread : [DRIVERS] AMD Chipset/SATA (3xx/4xx/5xx/TRX40)
    3) You have an ASUS ROG SS3|DTS Sound Unbound motherboard, so :
    You need Realtek Audio Drivers (UAD - ASUS ROG SS3-DTS MB) from the first post of this thread : [DRIVERS] Realtek Audio (MB | Intel 2xx/3xx/4xx/5xx & AMD 3xx/4xx/5xx).
    Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
    tcyr123 PC Specs
    CaseFormD T1
    Feb 2014
    2
    Hi MoKiChU,
    I appreciate the quick reply and have followed the steps exactly as you've stated.
    However, the problem still persists.
    USB-C audio does not work and does not detect my headphones when plugged in.
    My playback devices currently are Realtek(R) Audio (speaker), Sonic Studio Virtual Mixer (Completely useless, not sure where the sound output is coming out from) and Nvidia High Def Audio.
    I'm not sure if its a hardware problem because it did work at the start when I just completed the build.
    Are more potential solutions that I can try?
    MoKiChU PC Specs
    CaseBitFenix Enso
    Mouse Logitech G502
    MoKiChU's Avatar
    Aug 2013
    329
    583
    This thread could potentially help you (same issue as you) : https://rog.asus.com/forum/showthrea...-B550-i-Gaming
    If it's not the case, open a ticket with ASUS Support.
Tags for this Thread
