Results 1 to 7 of 7
    New ROGer Array Les_Garten PC Specs
    Les_Garten PC Specs
    Laptop (Model)Alienware OLD
    MotherboardZ97 Sabertooth, Dark Hero
    Processor5900X
    Graphics Card #1TitanX
    Graphics Card #2Strix 3080 OC
    OS Winders
    Jan 2018
    25
    Cool Need RAM advice for Dark Hero - 5900X build
    I need some advice for what RAM to buy.
    The Board will be Dark Hero, chip will be AMD 5900X, Strix 3080 OC, WD Black SN850, EVGA 1000 Platinum PSU, Workstation mainly, every once in a while Gaming. Not an overclcoking Junkie, just like the Board. Looking for Fast, but stable
    I am doing 64GB, either 2x32 or 4x16, will not ever go to 128GB
    Choosing G.Skill Trident Neo Z 3600mHz
    The 2 stick sets have higher CAS than the 4 stick sets.
    Here are the sets I am looking at, these sets are all on the QVL for this board and CPU. This is the order of preference, will these work for me? Any comments on these?
    1) F4-3600C14Q-64GTZN CL14-15-15-35 1.45V 64GB (4x16GB)
    2) F4-3600C16Q-64GTZN CL16-16-16-36 1.35V 64GB (4x16GB)
    3) F4-3600C16D-64GTZN CL16-22-22-42 1.45V 64GB (2x32GB)
    ROG Guru: Brown Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 11 64bit Pro
    Network RouterPfSence Intel i5-10210U 6 Port
    Accessory #1 TP-Link Gigabit 8&6 Port Switches
    Apr 2018
    65
    1,258
    They all are good choices. 64gb is a lot, but if you have use case, then do it.
    Of note, maybe an issue, the WD Black SN850 lacks AES 256-bit hardware encryption but is speed demon when not running slow
    https://www.pcgamer.com/wd-is-fixing...-motherboards/
    https://naponewsonline.org/wd-fixes-...-motherboards/
    so maybe Samsung 980 Pro might a be better choice, they seem very even (slow down not included), not sure ?
    Les_Garten PC Specs
    Processor5900X
    OS Winders
    Jan 2018
    25
    Quote Originally Posted by RedSector73 View Post
    I'm looking at both of those drives. WD is supposed to be coming out with a Firmware fix in July to address some issue. 980 Pro has some cache issues as well.
    I'm mainly wondering if the CAS 14 will work at those timings with 4 sticks.
    Apr 2018
    65
    1,258
    CAS14 @ 3800 4x8 for 32gb natively here.
    The ones your looking at will be samsung b-die. If there on QVL for motherboard your good to go.
    Another list thats handy to have
    https://www.amd.com/en/products/ryzen-compatible-memory
    Les_Garten PC Specs
    Processor5900X
    OS Winders
    Jan 2018
    25
    so for this set of RAM:
    Is the voltage an issue for long term use?
    Apr 2018
    65
    1,258
    Quote Originally Posted by Les_Garten View Post
    No, mine run 1.5v default and are F4-3800C14D-16GTZN running 14-16-16-36. Your selection and mine have a temp sensor built in as well.
    Your selection is a great binned RAM that uses raised voltage for stability and speed through better primary timings.
    A really good binned b-die can run a little higher than 1.5v, and the original samsung b-die specifications (that cover all of the ram inc bottom of the barrel) called 1.5v as maxmium safe working voltage.
  7. #7
    Les_Garten PC Specs
    Processor5900X
    OS Winders
    Jan 2018
    25
    Thanx!
Tags for this Thread
