Results 1 to 5 of 5
    ROG Member Array
    May 2014
    5
    Lightbulb M.2 Maximus XIII Hero questions
    Hello all,
    building a new PC - For the components, I will need to install -
    Intel 11900K CPU
    A NVIDIA GTX 3090
    One Gen 4 M.2
    One Gen 3 M.2
    = And an Elgato 4K60 Pro capture card.
    Can i install all these while keeping the GPU at 16x, or is this too many items?
    I know i can use the Gen 4 in the M.2_1 Slot and Maybe the second M.2 in the M.2_3 Slot,
    But will adding another PCI card lower the transfer rate of the GPU?
    Thanks in advance!! Sometimes it seems like Rubik wrote their MB manuals....
    ROG Member Array
    May 2014
    5
    So after further investigation:
    I need an 11th gen CPU, my 3090 in PCIEX16_1
    Then the Gen 4 M.2 in M.2_1
    Then the Gen 3 M.2 in M.2_3
    Then the Capture card in PCIEX_3 at 2x to keep all SATAs open.
    Correct?
    Quote Originally Posted by ajbrutico View Post
    Hello all,
    Intel 11900K CPU
    A NVIDIA GTX 3090
    One Gen 4 M.2
    One Gen 3 M.2
    ROG Enthusiast Array Grimpak PC Specs
    Grimpak PC Specs
    MotherboardROG Maximus XIII Apex
    Processori9 11900f
    Graphics Card #1Watercooled MSI Vega 64 Airboost OC
    Sound CardSteelseries GameDac
    Storage #1WD SN850 500GB
    Storage #2Raid0'ed 2xWD SN550 1TB
    CPU CoolerModified EK-MLC Phoenix + Eisbaer aurora 360
    CaseCooler Master SL600M Black Edition
    Power SupplySeasonic Focus gold 1000w
    Keyboard Steelseries Apex Pro
    Mouse Steelseries Rival 710
    Jun 2020
    50
    are you using all the sata ports? if not, turn them off to keep the capture card at 4x.
    ROG Member Array
    May 2014
    5
    Unfortunately I need 3 Sata ports so I have to leave at 2x
    ROG Enthusiast Array sl910 PC Specs
    sl910 PC Specs
    MotherboardMaximus 13 Hero PCB 1.02
    ProcessorIntel i9 11900K
    Memory (part number)Crucial 64 GB 3200MHz (4x16GB, CL22)
    Graphics Card #1Nvidia RTX 3090 Founders Edition
    Storage #1Samsung NVMe 980 Pro 1TB
    Storage #2Samsung NVMe 970 EVO Plus 2TB
    CPU CoolerNoctua NH-D15S chromax.black
    CaseLian-Li PC-A61WX
    Power SupplySeasonic PRIME TX-1000
    Keyboard Microsoft Wired Keyboard 600
    Mouse Microsoft Clasic Intellimouse
    OS Windows 10 Pro FR 21H1
    Jan 2020
    34
    On this MB there are so many USB headersd and ports that you can use an external dock (not a NAS) for SATA disks, connect it on one intel 10GB/s ports. It works very well, including the power saving function. This is what I decided to do. So I have disabled the intel SATA controller in the BIOS. For the external dock, I bought a QNAP TR-002. It doesn't need any driver.
    Regards
    sl910
Tags for this Thread
