XG279Q Monitor mounting
AIRic
Hello, I have 2 XG279Q monitors and I was looking at the manual for vesa mounting.
I looked at the online manual and it says this
The VESA wall mount kit (100 x 100 mm) is purchased separately.
•Use only the UL Listed Wall Mount Bracket with minimum weight/load 22.7kg (Screw size: M4 x 10 mm)
I'm not trying to mount them to the wall I just want a dual monitor mount to clear up some of my desk space for other things.
I was looking at something like this one
https://www.amazon.com/Dual-Arm-Monitor-Stand-Adjustable/dp/B07CWQ5S1Q/ref=psdc_490624011_t3_B08G8M7...
if you recommend a better one that's fine by me also.
I'm just not 100% sure that this one would work.
0 REPLIES 0
