Results 1 to 8 of 8
    New ROGer Array
    Jul 2021
    5
    CMK32GX4M2D3600C18 not higher than 3000
    Hopefully, somebody can help me.
    I do have an Asus Prime Z 490-A motherboard with a 10700KF and two CMK32GX4M2D3600C18 and latest bios 2201.
    I can't get the speed higher than 3000 while it's 3600 memory.
    settings 18-22-22-42 1.35V
    I have to set manually speed to 3000, if on automatic or if I put it myself higher than 3000, system goes in POST or blue screen.
    What am I doing wrong?
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    178
    2,335
    Hello,
    Have you tried adjusting the VCCSA voltage?
    Try values between 1.2 - 1.35v.
    New ROGer Array
    Jul 2021
    5
    Quote Originally Posted by Silent Scone@ROG View Post
    Hello,
    I will try today, keep you posted, thanks!
    ROG Member Array
    Nov 2014
    17
    Why is a lot of people having troubles to reach more than 3000 mhz on rams? I'm also in that boat, cannot get past 3000 with a 3600 kit without troubles, have a z490e board. Is this a known issue?
    ROG Guru: White Belt Array
    Dec 2013
    19
    114
    Something to check if you are in the correct slots. a2 and b2 or check the manual. I know it shouldn't need to be said but I have seen it happen.
    New ROGer Array
    Jul 2021
    5
    Quote Originally Posted by caheyne View Post
    1.25 and 3100mhz, that's the highest I can get! Strange.
  7. #7
    New ROGer Array
    Jul 2021
    5
    SOLVED
    My bad, thought had the right banks, checked again, everything okay now! XMP I or XMP II, all works!
    Thanks guys!
  8. #8
    New ROGer Array
    Jul 2021
    5
    Quote Originally Posted by bscool View Post
    Thanks!
Tags for this Thread
