Results 1 to 5 of 5
    New ROGer Array
    Jul 2021
    3
    Suggestions/Improvements for Asus XG27AQM (270hz with ELMB sync) please read
    I currently have a G7 monitor and this monitor to compare to and I'd like to give my suggestions to how to easily improve this monitor through a firmware update. (I hope we can update the firmware on this monitor).
    To add a little more info, looking at the service menu values for OD gain while changing the OD settings while not using ELMB sync I noticed the following
    OD 2 = 07
    OD 3 = 0C
    OD 4 = 1A
    Recommended OD for elmb sync
    OD gain = 12 for 200 hz and above
    OD 3 = 0C is perfect for Gsync VRR elmb sync as it works consistently well through out the refresh range (from 144 hz to 270 hz)
    elmb sync @ 144 hz with OD gain 0D (slightly more voltage than OD 3 but you could use OD 3)
    elmb sync @ 165 hz with OD gain 0D
    elmb sync @ 240 with OD gain 0D
    elmb sync @ 270 with OD gain 0D
    VS the default below for 144hz...
    elmb sync @ 144 with OD gain 1A (default OD 4)
    Suggestions:
    1. Through the service menu, I was able to change OD gain to 12 down from 1A when ELMB sync is enabled and it improved image quality with less inverse ghosting and no noticeable ghosting @ 270 hz and helped manage some overshoot from the lower refresh rates.
    2. Make an option to use OD 3 for elmb sync. I think it's the best compromise for quality. You can also do OD gain 0D (one step above) and it will look marginally better.
    I recommend the following options:
    -Firmware update to replace OD 4 with my recommended OD 3.5 (OD gain 12) that used by default whenever ELMB sync is enabled
    -Firmware update to replace OD 3 with this OD 3.5 and move OD 3 to 2. OD 2 isn't as suitable for VRR as the default OD 3 and OD 3.5 is even better in my opinion
    -Firmware update to add service menu settings to favorites and make them persistent
    I know this is a big ask but I'm tried of constantly losing my OD gain settings every time that I switch inputs or turn off the monitor.
    2. ELMB sync on this monitor has none of the following options:
    -Change location of motion clarity (top, middle or bottom) like some of the other elmb sync monitors have. (I wasn't able to find the setting despite using regular elmb and disabling gsync)
    -Change the strobe length which was also on some previous elmb sync enabled monitors. This monitor is actually TOO bright in my dark room with it's default ELMB sync brightness and there should be at LEAST an option to select Pulse Width at a lower value to get better motion clarity in exchange for dimmer screen (advantageous to some of us in darker rooms). Obviously adding an option for variable pulse width that's user defined is best but I'm sure you won't enable it because of the tuning you guys did on elmb sync
    Also I'd like to add that in the manual: https://dlcdnets.asus.com/pub/ASUS/L...QM_English.pdf
    Page 20 reads
    "ELMB/ELMB SYNC: ELMB can only be activated when Adaptive-Sync (DP)/
    Variable Refresh Rate is Off and the refresh rate is 120Hz, 144Hz, 165Hz, 240Hz,
    or 270Hz. ELMB SYNC allows you to turn on the function when Adaptive-Sync
    (DP)/ Variable Refresh Rate is On. This function eliminates screen tearing,
    reduces ghosting and motion blur when playing games. The function includes
    5-level clarity and position adjustment."
    Which makes me believe the 5 level clarity and position adjustment was planned for this monitor but is missing. Please implement this on elmb sync as on offset to what you guys already have. I like that elmb sync disables under 125 hz in order to prevent the double and triple crosstalk, I think it's a good compromise.
    3. Allow us to enable/disable elmb sync through DDC/CI. VPC codes allow for enabling and disabling gsync but not elmb or elmb sync which seems odd to me, some of us would like to create a utility to have "per app" profiles where I might enable elmb sync for some games but disable it for others.
    4. Allow us to change OD while elmb sync is active. We can already change OD using VPC codes (only when elmb is disabled) so let us change it programmatically, we could in theory make utility to change the OD depending on the app we are using (dark souls 3 is locked to 60 fps so OD 2 or 3 would be more ideal than OD 4 using elmb sync.
    These are my suggestions, this would MASSIVELY make this monitor that much better and it already gives the samsung G7 a run for it's money in my opinion. It has more consistent pixel response time across the board (light or dark transitions from what I can tell) with less overshoot and no flicker issues to worry about.
    Last edited by liquidshadowfox; 07-13-2021 at 03:33 AM. Reason: new optimal OD gain setting
    New ROGer Array
    Jan 2022
    1
    Quote Originally Posted by liquidshadowfox View Post
    OD 2 = 07
    OD 3 = 0C
    OD 4 = 1A
    Suggestions:
    Page 20 reads
    I just found this thread and as an owner of this monitor, I must say everything mentioned here is pretty much spot-on. All these features/implementations would make this monitor near perfect.
    However, it's a shame that a few months have gone by and no feedback was given in the meantime by someone at ASUS, specially since liquidshadowfox went through the effort of testing and figuring out the optimal settings for the monitor and compiled it all on this thread.
    The monitor is really good and has a lot of potential, but the OSD/firmware is holding it back. Most of these can be easily fixed through firmware updates, so please take it in consideration for future updates, specially since this is not a cheap monitor by any means.
    New ROGer Array
    Jul 2021
    3
    Quote Originally Posted by DaWorraps View Post
    I appreciate the feedback I think if asus did a firmware update on this monitor it could be WAY better than what it currently is. I have at least 2 ideas that would 100% take their ELMB sync to the next level but I don't know any asus contacts I can directly contact or channels to bring these great ideas forward.
    If someone from asus can please contact me so we can go over these ideas or please answer if a firmware update is possible for this monitor, I know a way that this monitor can be made MILES better than what it already is.
    ROG Guru: Orange Belt Array bass junkie xl PC Specs
    MotherboardZ690 Asus Strix D4 x 2 Bios 1604
    ProcessorRIG #1 12900 Ks @ 5.4/5.1 ring @ 1.36v/ RIG #2 12900 K @ 5.2/4.9 Ring @ 1.37v
    Memory (part number)DDR4 32GB Royals @ 4133 c15 Gear 1 / RiG # 2 32GB Team Group X @ 4000 cl-15-15-15-35 @ 1.52v
    Graphics Card #1RTX Asus 3090 TI LC + 240mm @ 2000 mhz @0.950v
    Graphics Card #2RTX 3080 EVGA XC3 Ultra @ 1860 mhz @ 0.842v
    Graphics Card #3MSI Gtx 1080 Ti + 360m aio @ 2000 mhz + 300 mem
    Sound CardMotherboard Realtec , Driver 87.46
    MonitorAsus Xg27AQM 27" @270 hz / Asus PG279Q 27" @165 HZ / AOC AG251FZ2 1080P @240hz
    Storage #1XPG 2TB/Samsung 970 evo+ 500 Gb / 970 Evo 1TB x 2
    Storage #22 tb HDD x 4
    CPU CoolerArtic liquid freezer 420mm / Deep Cool Gamermaxx 360mm v2 / Kraken G12 s36 360mm
    CaseThermaltake View 71 full Glass
    Power SupplyEvga 1000w Platnuim / evga 750 w
    Keyboard Corsair K95 Platnuim RGB
    Mouse Corsair Night Sword RGB
    Headset Razer Kraken 7.1 chroma
    Mouse Pad Asus Sheeth Large
    Headset/Speakers Logitech Z-5500 THX 5.1
    OS Windows 10-21h1 x64 Pro
    bass junkie xl's Avatar
    Oct 2017
    29
    365
    yes agreed with the above i almost returned the monitor cause of the bad form ware out of the box .... service menu tweaks evry time a gme is laaunched gets old quik....
    New ROGer Array
    Jul 2021
    3
    Any word asus?
    Quote Originally Posted by bass junkie xl View Post
    This is a beautiful monitor that needs a firmware update. Many users are now reporting that there is a studdering issue when it's 270 hz overclock with Gsync enabled and there should be an effort to fix that issue along with the locked OD.
    Laundry list
    1. Fix studdering with 270 hz overclock
    2. Fix ELMB sync not having selectable OD
    3. Fix OD 2, 3 and 4 as mentioned in my first post so that OD 3 can be selected for ELMB sync and OD 4 can be made less harsh
    4. Enable users to have the option to change the strobe phase and strobe length to allow users to change the strobe clarity (seems like with ELMB sync enabled the bottom 1/3 of the screen is best looking when I'd prefer the middle!). I'd like to mention THIS IS in the user manual but the option is unavailable in the OSD. Please fix this.
    Asus please, I love your product but gigabyte m27 X (240 hz with aim stabilizer sync) is actually BETTER looking despite having red phosphor AND it supports per application profiles for setting up backlight strobe on a per application basis! that's a $400 monitor beating a $700 monitor! You can even change the overdrive while backlight strobing + VRR is enabled! Please fix these issues or at least bring it up to the engineering team.
