Results 1 to 6 of 6
    ROG Member Array
    Apr 2015
    23
    ASUS ROG G751JT, Turn on TPM
    I have a 6 year old ASUS ROG G751JT and except for some earlier battery problems this laptop is a champion.
    Now With all the BS about Win 11 and the TPM requirements I have searched the UEFI (bios) and cannot find a TPM security chip switch. Probably don't have 2.0 but 1.2 would be nice.
    Anyone have any luck with this or knowledge if there is ability to plug in a TPM 2 chip on the motherboard.
    Thanks guys.
    ROG Guru: Blue Belt Array
    Nov 2012
    75
    795
    1. Run tpm.msc
    Here's a copy of mine: Note the Specification Version (that's the version that Windows 11 is looking for).
    2. My laptop is the G752VSK, having the Intel Core i7 7820HK CPU This is a 7th Gen Intel CPU (Windows 11 requires at least a 8th Gen Intel CPU)
    3. My laptop is a 2017 model and still doesn't meet Windows 11 minimum requirements.
    4. My Bios has no mention of TPM, I believe it is enabled through your Secure Boot function. You use the TPM.msc to clear the secure keys used during your secure boot.
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
    ROG Enthusiast Array
    Aug 2019
    30
    50
    Quote Originally Posted by jdfrench3 View Post
    1. Run tpm.msc
    I believe you need 8th Gen or later for TPM 2.0 to be available.
    Nov 2012
    75
    795
    Quote Originally Posted by gr8john6 View Post
    Read my post carefully.....
    My G752VSK has a 7th gen Intel CPU and I posted a copy of my TPM.msc displaying a TPM version 2.0.
    The TPM standard has been updated over the years, and its most recent release is TPM 2.0, which was released in October 2014.
    ROG Guru: Orange Belt Array
    Nov 2014
    8
    267
    Quote Originally Posted by Chris345 View Post
    Thanks guys.
    I believe entire G751J series does not have ANY TPM. Not even 1.2. For others, please do not post solutions if you haven't tested it over G751J laptop.
    ROG Guru: Green Belt Array
    Feb 2019
    129
    694
    Cant guaranteee it as I havent tried it but saw this elsewhere.
    https://www.youtube.com/watch?v=NivpAiuh-s0
Tags for this Thread
