Results 1 to 2 of 2
Thread: GPU problems?
    New ROGer Array
    Jul 2021
    1
    GPU problems?
    Hello guys
    I recently upgraded my computer system with a new CPU: Ryzen 3600, Motherboard: MSI B450Gaming Plus MAX, and Graphics card GTX 1660 Super this exact model: https://productz.com/en/asus-rog-str...-gddr6/p/5ayKo . I also used those same components to build my brother new PC and gave him my old GTX 1060 that I just replaced with the 1660 Super. The problem is with my 1060 I was regularly getting frame rates of 80-90 and this new graphics card is supposed to actually be better, yet I am getting 15-30 FPS. Is my GPU broken because my brother's PC with my older 1060 and the same internal components is getting better fps in almost every game, so I'm kinda dumbfounded. Can someone help me out here?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    344
    8,005
    Are you running the exact same settings? Same resolution, same quality settings, etc? If so then I would compare temperatures and perhaps run the same benchmarks on both systems to see if your issue is a CPU or GPU bottleneck.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
