Results 1 to 4 of 4
    ROG Enthusiast Array
    May 2016
    29
    GA35DX - change power supply
    I would like to change my graphics card from rtx2080s to rtx3070ti. Now i have 700W power supply. What power watt should I use the power supply?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    344
    8,007
    Nvidia recommends 750w minimum for systems with the 3070ti. If you are not overclocking you might be able to use that 700w power supply, but no guarantees. Your Ryzen 9 can also be pretty power hungry so it might be more comfortable to just get a new PSU and keep the old one as a spare.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    May 2016
    29
    Which ASUS power supply will fit my computer?
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    344
    8,007
    My guess is the manual doesn't specify PSU dimensions because one comes with the system but it's easy enough to figure out. ATX power supplies are generally the same height and width, varying the most by length (aka depth if we're looking at it as how far it extends from the rear panel of the case). So if you measure the existing PSU from the rear panel of the case to the front where the cords connect you can take that number and compare it to other PSUs online.
