Results 1 to 2 of 2
    New ROGer Array
    Apr 2021
    1
    Z590-F Gaming WiFi second m.2 drive issue
    Hi, I have fitted a second m.2 nvme Gen 4. The drive is recognised as a message about detecting new device at m.m_2 socket is displayed. It also says to use the device to to bios and onboard device config. No matter what combination of choices I make at m.2 config and cpupcie config mode I get the same message on startup. I assumed it would be st to leave them both on auto but still same result. Any ideas as driving me crazy.
    ROG Guru: Yellow Belt Array Zardoc PC Specs
    Zardoc PC Specs
    MotherboardASUS ROG Strix Z590-A Gaming WiFi 6 Intel® Z590 LGA 1200 PCIe 4.0
    ProcessorIntel® Core™ i7-11700 Processor 16M Cache, up to 4.90 GHz
    Memory (part number)Corsair Vengeance LPX 32GB (2x8GB) DDR4 3200MHz CL16 Memory Kit - Black (CMK16GX4M2B3200C16)
    Graphics Card #1ASUS Dual GeForce RTX™ 2070 OC edition 8GB GDDR6 Clock 1410 MHz Memory Clock 1750 MHz
    Sound CardOnbard Realtek 4080
    MonitorLG 27UK850-W 27'' 4K UHD IPS
    Storage #1Samsung 980 pro M.2 256 GB Pcie Gen 4.0
    Storage #2Samsung 970 Evo M.2 2280 2tb Pcie Gen3. X4
    CPU CoolerCryorig H7 Tower Cooler For AMD/Intel CPU
    CaseFractal Design Define R5 ATX Mid Tower Window Case Titanium 2X5.25 1X3.5 8X3.5IN
    Power SupplyCorsair AXi Series AX860i Digital 860W 80 PLUS
    Keyboard Logitech K800
    Mouse Logitech 705
    Headset/Speakers Klipsch THX
    OS Win 10 Ent 19043
    Network RouterAsus RT-AC86U
    Apr 2013
    47
    137
    I'm sorry, unless I'm blind, what message?
Tags for this Thread
