Results 1 to 3 of 3
    New ROGer Array
    Jul 2021
    2
    Exclamation [P5QL-E] Realtek Audio Console does not work
    I have an old motherboard that still remembers the 2008 P5QL-E.
    When installing the Realtek HD Audio UAD driver, it installs, but the application downloaded from the Microsoft Store - Realtek Audio Console - no longer works. After enabling it, in a moment it says "Unable to connect to the RPC service."
    What's the problem?
    The HDA driver installs without any problem.
    Maybe you can direct me to the error somehow, I would like to solve it.
    ROG Guru: Orange Belt Array Jesseinsf PC Specs
    Jesseinsf PC Specs
    Laptop (Model)N/A
    MotherboardASUS ROG Maximus XI Extreme (Z390)
    ProcessorIntel Core i9 9900K
    Memory (part number)Corsair CMW128GX4M4E3200C16 - 128GB (4x32)
    Graphics Card #1NVIDIA - GeForce RTX 2080 Ti FE
    Sound CardOnboard TOSLINK to powered speakers
    MonitorMSI Creator PS321URV (32 in 4k HDR600)
    Storage #1Samsung 980 Pro M.2 PCIe SSD 1TB
    Storage #2Samsung 970 Pro M.2 PCIe SSD 1TB
    CPU CoolerLian Li Galahad 360 (3x Uni fan SL120)
    CaseLian Li PC-011 Dynamic XL Black (ROG Certified)
    Power SupplyCooler Master V1200 Platinum
    Keyboard RAZER HUNTSMAN ELITE - LINEAR OPTICAL SWITCH (Red) w/ PBT Keycaps
    Mouse Razer Basilisk Ultimate with Charging Dock
    Headset Bowers and Wilkins P9 Signature
    Mouse Pad LOFTMAT (16x13 inch) Cushioned Gaming Mat - "The Gaming Slim"
    Headset/Speakers Vanatoo Transparent One Encore with Rel HT/1003 Subwoofer
    OS Windows 11 Pro for Workstations 64-bit
    Network RouterROG Rapture GT-AC5300 (Using Spectrum 400MB service)
    Accessory #1 Microsoft Xbox Elite Wireless Controller Series 2
    Accessory #2 2x Logitech BRIO ULTRA HD PRO WEBCAM
    Accessory #3 7 Uni Fan SL120 fans for PC case
    Jesseinsf's Avatar
    Mar 2019
    45
    390
    If the "Realtek HD Audio Universal Service" is not enabled in the Startup menu of the Task Manager then it will not work. If it's enabled or you don't see this in the Startup menu in Task Manager then it is not compatible.
    New ROGer Array
    Jul 2021
    2
    Thank you for your response.
    After installing UAD, Realtek is not visible in the Task Manager list. Only after installing the HDA, is it visible.
    How can I check which Realtek sound card chipset I have?
Tags for this Thread
