Results 1 to 7 of 7
    ROG Guru: Orange Belt Array Super Gnome PC Specs
    MotherboardROG Rampage VI Extreme Omega / ROG Crosshair VIII Formula
    ProcessorIntel® Core™ i9-9980XE / AMD 3950x
    Memory (part number)Corsair LPX Vengeance DDR4 2666MHz 128 GB / Corsair Vengeance LPX 32GB DDR4-3200 32GB DDR4 3200MH
    Graphics Card #1ROG-STRIX-LC-RTX3090TI-O24G-GAMING / Asus Turbo 2080 ti in SLI
    MonitorJAPANNEXT JN-VT500UHD 4K 50-inch LCD
    Storage #1Crucial MX500 1 TB / Sabient SB-ROCKET-NVMe4-500
    Storage #2Samsung 970 Pro 1 TB / ADATA XPG SX5500 Pro 3D NAND NVMe Gen3x4 PCIe M.2
    CPU CoolerROG Ryujin 360 / ROG Ryujin 360
    CaseThermaltake View 71 TG / Thermaltake View 31
    Power SupplyCORSAIR AXi Series, AX1600i 1600 watt / Thermaltake Toughpower iRGB 1200 watt
    Accessory #1 Noctua 140mm 3000 RPM x 2, Noctua 120mm 3000 RPMx3/ Noctua 140 mm 3000 RPM x 3
    Mar 2019
    31
    453
    Crosshair VIII Formula Chassis Fan #6
    HWMonitor is showing Chassis Fan #6 with this motherboard. I can't for the life of me imagine what fan this could be. There is no "Chassis Fan #6" in the manual so it is curious.
    If anyone knows specifically what fan this is: thanks a mint in advance for your knowledge.
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    233
    2,780
    Personally I use HWiNFO, but I'd recommend contacting CPUID for the most accurate response.
    ROG Enthusiast Array AfterShock PC Specs
    AfterShock PC Specs
    MotherboardAsus Crosshair VIII Hero
    ProcessorAMD Ryzen 5900x
    Memory (part number)F4-3200C14-16GFX
    Graphics Card #1EVGA RTX 3080 ti xc3
    Sound CardOnboard
    MonitorAsus VE278Q
    Storage #1Corsair MP500 M.2
    Storage #2Samsung SSD 970 EVO Plus 2TB
    CPU CoolerNZXT Kraken X3
    Casecorsair crystal 570x
    Power SupplyCORSAIR RMx Series 850W
    Keyboard Corsair Strafe mk2
    Mouse Logitech G903
    Headset Raze Nari Ultimate
    Mouse Pad Logitech PowerPlay
    OS Windows 11
    Network RouterNetgear NightHawk R7000
    Oct 2015
    62
    I'm pretty sure that's the chipset fan
    Mar 2019
    31
    453
    Hmm... Interesting. It spins at about double the speed of my case fans, like around 2300 rpm if I remember correctly. Does that jive with your thesis?
    Jun 2021
    29
    Quote Originally Posted by Super Gnome View Post
    Yes, that sounds about right for the chipset fan. It's funny, in the older BIOS versions you were able to adjust the chipset fan curve, but that ability has since been removed, not sure why.
    Also, I don't have a fan speed for the chipset fan in HWInfo anymore, so it's strange that you do. What BIOS version are you on?
    Mar 2016
    233
    2,780
    Quote Originally Posted by sc32valve View Post
    Go to settings on the sensor panel and tick "show all fans". Make sure you're running the latest build. If you've updated the AGESA, it's possible HWinfo will need to update the suite before certain sensors will function again.
  7. #7
    Mar 2019
    31
    453
    Forgive the year later reply, lol. This rig's fans really fly vs with a Rampage VI Extreme Omega based Intel system (and also a Rampage III Black Edition and 990x based system), and it is curious, so I was looking at HWMonitor again today. It still shows the fan listed as Chassis #6 as flying virtually double the speed of the other fans. And I always update my BIOS almost as soon as new ones are released, so then, as now, the latest (I dont install Beta versions though, but the latest in this case is not Beta).
    Edit: It turns out that fan is the AIO pump speed. In the BIOS under Monitor that is the only fan spinning that fast.
