08-09-2021 07:16 PM - last edited 3 weeks ago by ROGBot
08-10-2021 04:41 AM
08-10-2021 06:45 AM
MrAgapiGC wrote:
if you have a 11900k, you can use M2_1 since will become active cause the cpu make the port active to be use. Since the nvme is 3.0 will go to 3.0 speeds.
M2_2 will be disable by default (do not use) making it active will drop the gpu to 8x and will drop more when M2_3 and 4 is added. So do not use it there.
You can use M2_3 and M2_4 (#4 need to enable pcie in bios to get speeds) perfect fine also.
If you get a gen4 put it on M2_1 and the Gen 3.0 on 3 or 4 (these 2 use gen3 only) if you use gen4 nvme will go to 3.0 speed.
09-18-2021 05:59 AM
mpoffo wrote:
Thank you very much. Very much appreciated!
09-17-2021 07:23 PM
MrAgapiGC wrote:
Since the nvme is 3.0 will go to 3.0 speeds...
