Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    ROG Enthusiast Array DarCraft PC Specs
    DarCraft PC Specs
    MotherboardAsus Rampage V Extreme with EKWB Water Cooling
    ProcessorIntel Core i7-5960X Extreme Edition
    Memory (part number)Kingston HyperX Predator DDR4 32GB 3000MHz 4x8GB Kit (HX430C15PBK4/32)
    Graphics Card #1GIGABYTE GeForce GTX 1080 Ti AORUS XTREME EDITION 11 Гб GDDR5X
    Graphics Card #2GIGABYTE GeForce GTX 1080 Ti AORUS XTREME EDITION 11 Гб GDDR5X
    Sound CardCreative Sound Blaster AE-9
    MonitorAcer 32" Predator XB321HK
    Storage #1Samsung SSD 970 PRO 1TB (M.2 PCI-E 3.0 x4)
    Storage #2Samsung SSD 850 PRO 1TB (SATA-III)
    CPU CoolerEK-FB ASUS R5E Water Monoblock
    CaseSilverStone Fortress FT02B Modding for Water Cooling
    Power SupplyEVGA SuperNova 1200 P2
    Keyboard Microsoft SideWinder X4 Keyboard Black
    Mouse Logitech G Pro Wireless
    OS Windows 10 Pro x64
    Network RouterASUS RT-AC86U
    Nov 2015
    28
    Exclamation Help!! Please check my Overclocking Settings for RVE&5960X!!!
    I ask for the help of overclocking experts to check my motherboard settings for the safety of the set values!
    Has it exceeded the recommended thresholds?
    Screenshots of the bios settings are here:
    https://disk.yandex.ru/d/d2sA1WgXlR-1TA
    Rampage V Extreme BIOS 4101, CPU 5960x 4.5 GHz, Kingston HyperX Predator 32GB 3000MHz overclocked to 3133MHz with BCLK 98MHz
    I am grateful in advance for any comments and corrections!
    DarCraft PC Specs
    Nov 2015
    28
    Do I need to lower the following parameters to safe values?
    PCH Core Voltage-1.100
    PCH I/O Voltage - 1.500
    VCCIO CPU 1.05V Voltage - 1.100
    VCCIO PCH 1.05 V Voltage-1.100
    CPU Cache Voltage 1.246875 and CPU System Agent Voltage 1.1000 are not high? Thank you for any help!
    ROG Guru: Green Belt Array
    Feb 2019
    128
    608
    PCH is generally good at stock. Ive never had to mess with it. Whats your cache speed running at and your Package temp?
    DarCraft PC Specs
    Nov 2015
    28
    DarCraft PC Specs
    Nov 2015
    28
    Quote Originally Posted by BigJohnny View Post
    CPU Core: 1.312 V (Temp 37 C°)
    CPU VRM / CPU Input Voltage: 1.968 V (Temp 41 C°)
    CPU VID: 1.296 V
    CPU Cache: 1.246 V
    CPU and VRM they are cooled by a EK-FB ASUS R5E Water Monoblock.
    https://www.ekwb.com/shop/ek-fb-asus...l-original-csq
    By STOCK, you mean AUTO or Set the STOCK values Manually?
    PCH Core and PCH I/O switch to AUTO and VCCIO CPU 1.05V / VCCIO PCH 1.05 V from 1.100 to 1.05 V ?
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS z490 maximus XII Apex 2nd x299 Rampage VI Apex
    Processori9-10900k & i9-9940x
    Memory (part number)Trident-Z 3600c16 2nd Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block 2nd Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Cooler2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 2nd EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum 2nd Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Optimus Foundation copper plexi 2nd Optimus SigV2
    Accessory #2 ModmyMods clear coolant
    Accessory #3 ModMyMods 3/8-5/8" clear soft tubing/ MORA 360 Pro x2
    ThrashZone's Avatar
    Oct 2017
    30
    418
    Yes pch 1.05v is default so either this or auto is fine if you need a little more 1.1v
    Input voltage also would be fine and recommended at 1.9v max assuming you're using llc-4 or 5
    Haswell-e would get toasted on newer bios really focused on broadwell-e processors so it's good you limited
    vccio cpu to 1.1
    vccio pch to 1.1
    Otherwise bios would zap these up to 1.35v++ when enabling xmp profiles and kill your 5960x is short time.
    I usually peg both to system defaults 1.05 as well
  7. #7
    DarCraft PC Specs
    Nov 2015
    28
    ThrashZone
    Thank you for your help!
    So, you are advising to reduce the CPU input voltage from 1.930 to 1.900, right?
    Both VCCIO CPU 1.05V Voltage and VCCIO PCH 1.05V Voltage should be reduced from 1.10 to 1.05, right?
    By the way, my CPU Load-line Calibration is set to Level 7. You recommend lowering it to Level 4 or 5, right?
    MB: Asus Rampage V Extreme with Latest BIOS v4101
    CPU: Intel Core i7-5960X
    RAM: Kingston HyperX Predator DDR4 32GB 3000MHz PC4-24000 CL15 1.35V (4 x 8 GB Kit) HX430C15PBK4/32
  8. #8
    ThrashZone PC Specs
    ThrashZone's Avatar
    Oct 2017
    30
    418
    Nice rig
    Think only thing I would really change is the llc-7 down a little to llc-6
    LLC-# you probably already know controls how much input voltage drops under stress/ vdroop
    If you use hwinfo64 and monitor the min-max input voltage you'll see it
    At 7 there is very little vdroop
    https://www.hwinfo.com/download.php
    Vdroop is a good thing so if it does not create instability set it to 6 and really, a good max on input voltage is under 1.95v and you're just a little above that at 1.97v I wouldn't use this 24/7 but just benchmarking is okay before I said 1.9v max to be more on the conservative side.
    On auto input voltage would be closer to 2.0v lol so at least you're under this
    Only other item is min-max cache at 44 this is pretty wild your system is stable
    Min 24 and max 38 at your same cache voltage of 1.1v is what I've used so seeing you use 44 is pretty wild but again if you're stable leave it alone :-)
    Otherwise you're already using pretty good max limits on voltages so as long as you're stable seems good, your chip and board are doing well on newer bios.
  9. #9
    DarCraft PC Specs
    Nov 2015
    28
    ThrashZone
    I really appreciate your help and advice.
    Thanks
  10. #10
    DarCraft PC Specs
    Nov 2015
    28
    ThrashZone
    Should I turn off or leave on Auto the ASUS MultiCore Enhancement?
    Auto is the default value
    Thanks
