Results 1 to 3 of 3
08-14-2021 02:26 PM #1
- Join Date
- May 2017
- Reputation
- 10
- Posts
- 2
Audio FIX Z490-E/F crackling/Popping/electrical noise
Do you have crackling/Popping problems with random electrical noise?
I've had months of sound problems, even after deleting drivers and putting it all over again and even formatting
I came to explain how I solved it and help others with the same problem (I've tested it in 2 builds "Z490-E and Z490-F" with this problem after 3 months everything is still ok)
https://rog.asus.com/forum/showthrea...ftware-Threads
1- Clear all sound drivers explained by MoKiChU
2- Install MoKiChU Realtek Audio Drivers (UAD - ASUS ROG SS3-DTS MB)
3- Open the "Armoury crate" and in tools you will notice that the sound driver has no version, select the sound driver and update (this step is important, I have already tried step 1 and 2 the sound is excellent, but the crackling continues )
4- restart
(5- optional) if you get hoarse sometimes the RGB, BT and network card gives latency the ideal is to update too, if you use DPC Latency you will notice that changing the lights or using BT or uploading too much gives latency breaks
I've had months looking for a solution for me it's really ridiculous for a board like this to have sound problems so I hope I've helped someone if nothing gave the only solution must be an external sound card I don't think replacing the board will help but if you find it, share it too
08-14-2021 02:50 PM #2
Saltgrass PC Specs Motherboard Maximus Z790 Hero Processor i9 13900K Graphics Card #1 EVGA RTX 3090 FTW Sound Card On Board Monitor Dell AW3420DW Storage #1 Samsung 980 Pro 2 TB Storage #2 Samsung 860 Pro 1 TB CPU Cooler Cooler Master Hyper 212X Case Cooler Master Power Supply Antec HCP Platinum 1000 Keyboard ASUS Strix Flare Mouse ASUS Chakram Headset/Speakers Logitech wired 5.1 OS Win 11 Pro Network Router ROG Rapture GT-AX11000/AXE11000 Accessory #1 VR Headset Accessory #2 Saitek X52 Accessory #3 Intel AX411
- Join Date
- Jan 2014
- Reputation
- 18
- Posts
- 670
You leave out some fairly important information, i.e. what sound output device are you using? I bring this up because I noticed on one of my systems (not the Z490-E/F), there was a firmware update for the spdif output making static noises.
Otherwise, I have seen no sound problems with either the Z490 or Z590 Maximus Hero boards..
08-14-2021 09:19 PM #3
- Join Date
- May 2017
- Reputation
- 10
- Posts
- 2
