Results 1 to 6 of 6
    New ROGer Array
    Jul 2021
    33
    8
    TUF Gaming VG34VQL1B artifacts / shimmering
    I've been having a blast with this monitor. Speed, color reproduction, even it's limited HDR capabilities -> perfect upgrade.
    I do have two issues though:
    1. It doesn't seem to send any form of HDR certificate, which could be the reason I have to switch HDR on and off manually all the time.
    2. Blue/violet artifacts/shimmering in dark spaces at higher speeds.
    The 2nd is something I didn't notice at first, but now I can't seem to look past it anymore. It's almost like chromatic abberations in photos?
    I've been using VA monitors for the past years and I've never experienced something like this.
    I tried to play around with the OD setting a little but it didn't really change much (that I'd notice).
    Any advice?
    ROG Guru: Brown Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 11 64bit Pro
    Network RouterPfSence Intel i5-10210U 6 Port
    Accessory #1 TP-Link Gigabit 8&6 Port Switches
    Apr 2018
    65
    1,253
    There is a WHQL driver & ASUS DisplayWidget Lite, have you tried these ?
    https://www.asus.com/Displays-Deskto...Desk_Download/
    New ROGer Array
    Jul 2021
    33
    8
    thanks. Yes I do have those drivers installed. I've tried different things, like enabling and disabling G-Sync/FreeSync/VRR, various overdrive settings, 8-bit and 10-bit color depth.
    New ROGer Array
    Jul 2021
    33
    8
    PS: I have no idea I should make a video or something, but even scrolling this site up & down quickly, white letters on black background, will make the letters turn into "rainbow" while they're moving. Letters stay clearly visible, they're just not white anymore.
    New ROGer Array
    Jul 2021
    33
    8
    Overdrive seems to affect the artifacting. Several other people seem to be having this issue as well:
    https://www.reddit.com/r/ultrawidema...l1b_need_help/
    https://www.reddit.com/r/Monitors/co...n_asus_tuf_uw/
    New ROGer Array
    Jul 2021
    33
    8
    I changed the cable for a new DP 1.4 version, the problem persisted.
    Only turning off OD completely when HDR is enabled will get me rid of the artifacts. Hopefully there'll be a firmware update to address the issue.
Tags for this Thread
