Results 1 to 4 of 4
08-18-2021 07:36 PM #1
- Join Date
- Jun 2021
- Reputation
- 18
- Posts
- 10
GT-AX11000 - not sure what is going on
I have two GT-AX11000 working well in an AIMesh. Using Firmware Version:3.0.0.4.386_44266 on both.
If I leave it as is, no problems.
I would like to use VPN Fusion so that I can direct one computer on my network through a OpenVPN tunnel, and all others use default (Internet).
No problems adding the OpenVPN connection to VPN Fusion, however when I do this many of my clients on my home network start to lose their connection - it becomes very unstable. In the case of my cell phone, it seems to continuously try to connect to my wifi, and fail... repeat.
To fix this, I have to factory reset the router, and upload my last known good CFG save (very glad I make a habit of saving my CFG before and after any config changes, and keep a history of these saves).
So for now, I am just using a VPN client on that one computer that I was hoping to use VPN Fusion for. All is stable.
Not sure if anyone else has seen this?
08-19-2021 01:38 AM #2
RedSector73 PC Specs Laptop (Model) FA506IU-AL130T x 2 Motherboard ROG CROSSHAIR VIII HERO (WI-FI) Processor AMD Ryzen 9 3900X 12-Core Processor Memory (part number) 4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die Graphics Card #1 Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC) Sound Card Arctis DAC Monitor Asus ROG Swift PG348Q Storage #1 ADATA SX8200PNP 1TB Storage #2 2 x Samsung SSD 840 EVO 250GB CPU Cooler Coolermaster Liquid Pro Master 360 Case EVGA DG-87 Gunmetal Grey Gaming Case Power Supply EVGA SuperNOVA G2 750W Gold Power Keyboard Corsair K95 RGB Platinum Mouse Corsair Gaming Sabre RGB Gaming Mouse Headset ARCTIS Pro Wireless Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large OS Windows 11 64bit Pro Network Router PfSence Intel i5-10210U 6 Port Accessory #1 TP-Link Gigabit 8&6 Port Switches
- Join Date
- Apr 2018
- Reputation
- 65
- Posts
- 1,302
Maybe worth trying Merlin (This is an enhanced version of Asuswrt - the firmware) since it recently supports this router.
https://sourceforge.net/projects/asu...11000/Release/
I doubt your current CFG file will work with this firmware, typically you start from start with this to get the best results.
It might be worth trying, I know it was for my old Asus router for well over 8 years. Does not use VPN fusion rather has another implementation (policy-based routing) described here https://github.com/RMerl/asuswrt-mer...-based-routing and would be considered a superior implementation vs. vpn fusion and most likely work as intended (assuming you set VPN up correctly, it is a different implementation)
Only other thing to note is early days with this router for this Merlin firmware but you will find it has good user base which collectively supports the implementation and Merlin / others who actively investigates issues.
https://www.snbforums.com/Last edited by RedSector73; 08-19-2021 at 01:53 AM.
08-20-2021 01:22 PM #3
- Join Date
- Jun 2021
- Reputation
- 18
- Posts
- 10
08-20-2021 02:24 PM #4
- Join Date
- Apr 2018
- Reputation
- 65
- Posts
- 1,302
Yes you can switch back if it does not work out.
