08-20-2021 08:17 PM
08-21-2021 09:22 PM
08-22-2021 04:35 PM
08-22-2021 04:36 PM
xeromist wrote:yes
Are you using the aux power connector?
08-23-2021 11:58 AM
08-23-2021 01:32 PM
xeromist wrote:I didn't see any unusual.
You may want to break out a flashlight and do a visual inspection of the slot. Make sure nothing is caught in there or other visible damage.
09-02-2021 05:15 PM
Geremia19 wrote:I waited 1½h, and it never got past the "BIOS is updating LED firmware".
never waited long enough to know if it ever gets past that
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: American Megatrends Inc.
Version: 1206
Release Date: 07/15/2021
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 16 MB
Characteristics:
PCI is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 5.13
09-02-2021 09:26 PM
09-04-2021 11:42 AM
xeromist wrote:Though the BIOS doesn't keep fTPM disabled now…
Hrmm, interesting. Thanks for reporting back!
