Results 1 to 3 of 3
    New ROGer Array
    Jul 2021
    2
    Thermopads or other cooling - M.2 SSD - GL553VD
    Hi
    I installed new M.2 NVMe SSD recently and it's temperature while gaming is higher than 50°C, but still lower than 70°C which is the manufacturer limit (measurements made with samsung magician). I would like to know if someone has in one's laptop thermopads or radiators on M.2 SSD which are glued on laptop cover. Should adding such a termopad decrease temperarure significantly? I saw one video only, so it's not much: https://youtu.be/fHIHl3U3DOg
    In the video laptop casing is metal not plastic like mine (https://youtu.be/B4NaAvtPTzM?t=36), though. I would like to decrease temperature to 50°C to increase durability.
    Thanks for any replies
    ROG Guru: Brown Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 11 64bit Pro
    Network RouterPfSence Intel i5-10210U 6 Port
    Accessory #1 TP-Link Gigabit 8&6 Port Switches
    Apr 2018
    65
    1,278
    EK makes a popular and attractive m.2 heatsink.
    However, you should know that if you were using it for storage, you want NAND to be cold, but for writes the NAND needs to be warm and cutting the temp will reduce the life.
    Watch this video from 6:15 onward.
    ROG Guru: Green Belt Array
    Feb 2019
    129
    694
    Quote Originally Posted by Gabryu317 View Post
    Hi
    The only thing you need to cool is the controller. Biggest chip near the connector and that can be done with s simple ram sink to cover just the controller. The storage ICs prefer around 40C and running them too cool is actually not beneficial. Its the controller that gets hot and will lead to throttling if it gets too hot. Air flow in a laptop can also be problematic. Dont know that lay out but should have intake vents near the M.2 mount.
Tags for this Thread
