Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    ROG Enthusiast Array
    Apr 2012
    34
    GTX 1060 card won't boot up on Rampage 6 Extreme Encore board!
    Hi guys, I have 2 systems.
    1)Amd 5900X
    Asus Dark Hero VIII board X570
    2) Intel 10920X
    Asus Rampage VI Extreme Encore board X299
    I have 2 gpus: Nvidia 3090 FE and an old EVGA GTX 1060
    Both the 3090 and 1060 cards work perfectly on the Amd system with the Dark Hero VIII board.
    But only the 3090 card works on the Intel system with the Rampage VI Extreme Encore board.
    The 1060 card won't boot up at all on the Intel system. I have a White led on the top right of the Encore board which indicates that there is a VGA issue.
    Does anyone else have this issue with the Encore board with old GTX 1060 card?
    It's just weird that the 1060 boot up fine on the Dark Hero board.
    Any help would be appreciated.
    New ROGer Array
    Aug 2021
    19
    21
    I've experienced this issue on a z590 board with both an AMD RX 580 and a Nvidia GTX 1060.
    I worked around the problem but using the iGPU to get to Windows.
    Once you get into Windows, the solution is to find and install an updated firmware for the GPU.
    Apr 2012
    34
    Quote Originally Posted by Shark007 View Post
    What you mean update the firmware for the GPU?
    I thought GPU only has driver from Nvidia?
    I don't have any CPU with iGPU, both my Intel 10920X and Amd 5900X don't have iGPU
    Apr 2012
    34
    I already tried to update to the latest Bios for the Rampage 6 Extreme Encore board. I also tried to uninstalled the Nvidia drivers. And still can't get the 1060 to boot up on the Rampage 6 Extreme Encore board.
    New ROGer Array
    Aug 2021
    19
    21
    As previously posted . . .
    This can be done on any system that gets into Windows.
    After updating the Firmware, move the GPU back to the system that failed in the past.
    EDIT: Firmwares are NOT generic. You must find one from the manufacturer of the GPU.
    Apr 2012
    34
    My card is an EVGA GTX 1060 card, but I looked up on google, there is no Firmware for GPU. What firmware are you talking about? The Bios for the GPU?
  7. #7
    New ROGer Array
    Aug 2021
    19
    21
    Quote Originally Posted by jincuteguy View Post
    Yes. I called it firmware so that you would differentiate it from the motherboard bios.
    Use this source for the update
    https://www.techpowerup.com/vgabios/...memSize=&since
  8. #8
    Apr 2012
    34
    My 1060 is not on there. It is an EVGA 3gb ACX 3.0 FTW 1060 card
  9. #9
    New ROGer Array
    Aug 2021
    19
    21
    check this part number, 03G-P4-6162-KR
    If that matches, its this bios, https://www.techpowerup.com/vgabios/...60-3072-160725
  10. #10
    Apr 2012
    34
    No, that's not the right part #. Mine is 03G-P4-6367-KR. It's the ACX 3.0 FTW one
    I just don't get why it boot up and works fine on my Amd X570 Dark Hero board, but not the Intel Rampage 6 Extreme Encore board.
    They're both from Asus.
