Results 1 to 3 of 3
    ROG Guru: White Belt Array
    Jun 2014
    22
    85
    Wrong Boost on i9-10850k (allCore)?
    Hello,
    i have a i9-10850K on an Asus ROG Z590-A-Board.
    In the Bios, i disabled MultiCoreEnhancment, so the CPU is runing at Intel-Specs.
    When i run Prime95, all cores goes up to 4800Mhz at 1.232V.
    So far, so good...
    After one minute, all Cores droping to 4500Mhz at 1.168V and stay there forever (as long as Prime is runing).
    I thought, the i9-10850K has AllCore Frequ of 4800Mhz, but mine seems to havethis only for a minute...
    I know, that after 56 Sec PL1 "jumps in" (because PL2 should only run 56 Sec), but the CPU must be able to keep 4800Mhz as long as there i want?!?
    Or is it normal, that the CPU drops to 4500Mhz after 1 Minute?!?
    Temps are good, about 60°C...
    Thanks!
    ROG Enthusiast Array Betroz PC Specs
    Betroz PC Specs
    MotherboardAsus Maximus XII Apex
    Processori9 10900K
    Memory (part number)32GB G.Skill TridentZ F4-4000C17D-32GTRGB
    Graphics Card #1Asus 3080 Ti TUF OC
    MonitorLG 38GN950-B
    Storage #1Intel Optane 900p
    Storage #2Adata SX8200 PRO
    CPU CoolerLiquid Freezer II 360
    CasePhanteks Eclipse P500A
    Power SupplySeasonic TX-1000
    Mouse Logitech G502
    Headset Sennheiser 660S
    OS Windows 10 PRO
    Betroz's Avatar
    Nov 2019
    21
    43
    You need to adjust the power limits in BIOS or else the CPU just follows Intel spec.
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    Motherboardz490 XII Apex 2nd x299 VI Apex 3rd x99 sabertooth
    Processori9-10900k w/Foundation & i9-9940x w/SigV2 & 5930k w/ek-Magnitude
    Memory (part number)Trident-Z 3600c16 2x8 2nd Trident-Z 3600C16 4x8 3rd 3200c14 4x8
    Graphics Card #1Titan Xp & 1080ti FTW3 both water cooled & evga 980ti gaming on air
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Cooler2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads & 2 Test Benchs
    Power SupplyEVGA 1000P2 & 1200P2 & 850p2
    Keyboard 3x Logitech G710+
    Mouse 3x Red dragon Perdition
    OS Linux-Cinnimon 20.2 & Win-7-10-11 pro
    Accessory #1 Optimus Foundation copper plexi 2nd Optimus SigV2
    Accessory #2 Mayhems clear all
    Accessory #3 ModMyMods 3/8-5/8" clear soft tubing/ MORA 360 Pro x2
    ThrashZone's Avatar
    Oct 2017
    30
    422
    Quote Originally Posted by JoergH View Post
    Hello,
    So far, so good...
    Thanks!
    You'd want multicore enhancement on Enabled-Remove all limits otherwise Intel crappy power limits will mess up everything you run.
    Other performance killing settings are these
    Plenty of youtube videos showing this
    https://www.youtube.com/watch?v=4th6YElNm5w
    https://www.youtube.com/watch?v=qQ_AETO7Fn4CPU
    Core/Cache Current Limit Max. [255.75]
    Long Duration Package Power Limit [4095]
    Package Power Time Window [448]
    Short Duration Package Power Limit [4095]
    https://www.youtube.com/watch?v=osMrZNeguQk
    https://www.youtube.com/watch?v=cssbWlpmTho
