Asus TUF505GE problem with intel turbo boost
mickeymkd
I have a strange problem with this laptop.
The configuration is:
Intel i5-8300h
Nvidia 1050ti 4gb
Kingston DDR4 2666Mhz 16Gb
Kingston 256gb nVme SSD
1tb HDD
I had keep getting different BSOD errors in windows 10 which point to ntoskrnl.exe, and the errors only occur when the laptop is plugged in. On battery power it works fine.
In the meantime I tested the RAM with memtest, HDD with hdtune and everything was fine.
By accident I discovered that when intel turbo boost is enabled (which is by default enabled) I get different BSOD errors in windows 10 and by disabling it in windows power settings the laptop now works fine when is plugged in.
I cant find an option in the bios to disable the turbo boost. The bios version is v308 which is the latest.
Have somebody else experienced problems with Intel turbo boost?
mickeymkd
It would be nice to have an option disable/enable intel turbo boost from bios.
90183
C:\Windows\System32\powercfg.exe /SETACVALUEINDEX SCHEME_CURRENT SUB_PROCESSOR PERFBOOSTMODE 0
abactuon wrote:
90183
Thanks.
