Results 1 to 8 of 8
    New ROGer Array
    Aug 2021
    9
    B550-F Audio Crackling
    Hello, I have a new B550-F paired with a 5600X. The issue I have is that sometime the audio pops or cracks, especially with Windows sound. This is very noticeable when using Windows's slider to adjust volume when the classic sound is playing.
    I can ear the audio just fine in games, discord, multimedia and stuff. Sometimes I can barely ear some popping while watching livestreams so I suppose it only happens with certain frequencies.
    What I already tried:
    - Clean Windows 10 install;
    - Clean Windows 11 install;
    - Clean audio driver and reinstall them;
    - Try older audio driver version;
    - Change headphones;
    - Change from rear audio panel to front audio panel, no differences.
    The issue doesn't seem to be present on Ubuntu though. Any idea? Do I have a faulty motherboard?
    Thank you and have a nice day.
    Video of the issue found on the internet:
    https://streamable.com/tdvg47
    https://streamable.com/iozb2i
    ROG Guru: Brown Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 11 64bit Pro
    Network RouterPfSence Intel i5-10210U 6 Port
    Accessory #1 TP-Link Gigabit 8&6 Port Switches
    Apr 2018
    66
    1,342
    Quote Originally Posted by OctaveFuzz View Post
    Easy to answer, NO, If you did, it would be repeatable in every OS.
    It's a driver issue.
    ROG Enthusiast Array
    Jul 2012
    13
    48
    - Use Mochiku's audio driver from this board.
    - Use msi based interrupt
    This issue has been discussed many times already and is easily solved.
    Cheers.
    New ROGer Array
    Aug 2021
    9
    Quote Originally Posted by RedSector73 View Post
    Quote Originally Posted by Escorpiom View Post
    Cheers.
    Thank you for your replies. Can you please link me some resources? I tried looking up on Google to no avail.
    Apr 2018
    66
    1,342
    New ROGer Array
    Aug 2021
    9
    Thank you. I installed these drivers by following the instructions. I even enable MSI as suggested and I disable hibernation to no avail.
    The crackling is still there.
  7. #7
    New ROGer Array
    Oct 2020
    12
    Same problem, crackling is present whatever I do. (Latest mobo bios, latest drivers, windoze 10)
    Workaround is to run this stupid realtek audio panel go to "device advanced settings", change output from headphone to front speaker output and then back, crackling is gone until next restart.
  8. #8
    New ROGer Array
    Aug 2021
    9
    Quote Originally Posted by xenon2 View Post
    Thank you man, this actually works just fine. I'mcurrently using the latest MoKiChU driver, MSI mode and hibernation disabled and the crackling is still there. Doing this switch from the panel is the only thing that makes it stop.
