Results 1 to 8 of 8
    ROG Member Array ZeroCool22 PC Specs
    ZeroCool22 PC Specs
    MotherboardASUS ROG STRIX B550-F GAMING (WIFI)
    ProcessorRYZEN 9 5900X
    Memory (part number)CORSAIR 2x16 3000 Mhz CMW32GX4M2C3000C15
    Graphics Card #1MSI GTX 1080TI 11GB GAMING X
    CPU CoolerCOOLER MASTER MASTERAIR MA610P RGB
    Power SupplyAEROCOOL KCAS 700WFULL RANGE
    OS Windows 10 x64
    Apr 2021
    13
    Exclamation 5900x base clock 3.6 Ghz, it should be 3.7 Ghz, what could be the problem?
    MB: ASUS ROG STRIX B550-F GAMING (WIFI)
    Thx in advance.
    UPDATE:
    ✅DOUBT SOLVED
    This guy have same CPU and have same lectures, also he explained why:
    >> https://linustechtips.com/topic/1370...mment=14969091
    ROG Guru: Brown Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 11 64bit Pro
    Network RouterPfSence Intel i5-10210U 6 Port
    Accessory #1 TP-Link Gigabit 8&6 Port Switches
    Apr 2018
    65
    1,234
    What BIOS are you running ?
    ZeroCool22 PC Specs
    OS Windows 10 x64
    Apr 2021
    13
    Quote Originally Posted by RedSector73 View Post
    2407
    ZeroCool22 PC Specs
    OS Windows 10 x64
    Apr 2021
    13
    I got this reply in Reddit AMD:
    That's the idle clock, not the base clock. There's a difference.
    That's the minimum it will run under load if the boost algorithm is limited by temps or other limiting factors.
    5950x here, same idle clock.
    What do you think?
    Apr 2018
    65
    1,234
    Yeah, I agree with that comment.
    Might be worth moving to latest BIOS as well. Version 2423
    If you don't mind me asking, how come your running DDR4 @ 3000 RAM and not supported 3200 speed or little higher, given your running 5900x and this is best performance increase you can do for Ryzen, or just future upgrade thing and initial cost reduction becuase you had RAM sitting around ?
    ZeroCool22 PC Specs
    OS Windows 10 x64
    Apr 2021
    13
    Initial cost reduction.
    In the future when i can, will upgrade to a more fast RAM.
  7. #7
    ZeroCool22 PC Specs
    OS Windows 10 x64
    Apr 2021
    13
    Mmm, everything is working fine, you think i should upgrade to the latest one?
    Anyways, i always use the Flash Button feature, so if something don't likes me of the last BIOS, i always could "downgrade" to a previous one.
  8. #8
    Apr 2018
    65
    1,234
    Yeah, u can always downgrade if you find an issue.
    Can I suggest you go with at least DDR4@3600 CL16 2xDR modules, when you get around to it.
Tags for this Thread
