Results 1 to 7 of 7
    New ROGer Array Viper_Maniac PC Specs
    MotherboardAsus Strix B450-F Gaming
    ProcessorRyzen 5 3600
    Memory (part number)16GB Gskill Trident Z RGB 3600mhz
    Graphics Card #1Gigabyte G1 Gaming 1080 8GB
    Sound CardOnboard
    Monitor2x Acer G246HL
    Storage #1Samsung 850 Evo 250GB SSD
    Storage #23x WD Blue 1TB HDD
    CPU CoolerCooler Master Hyper 212 Black Edition
    CaseLian LI Lancool II
    Power SupplyCorsair 550w
    Keyboard Cooler Master Devastator 3
    Mouse Cooler Master Devastator 3
    Headset Asus TUF H3 Gaming
    OS Windows 10 21H1 64Bit
    Sep 2021
    5
    Question Asus B450-F Mobo Networking Issue
    Hi I'm having an issue with my networking on my Asus B450-F Strix Gaming mobo. I usually try to fix things myself but this time I'm a bit stumped.
    My specs:
    Ryzen 5 3600
    Asus B450-F Gaming
    16GB Gskill Trident Z Neo 3600mhz
    Using onboard audio and ethernet
    When I'm on the internet I keep having my browser (Firefox) randomly not connect to a website. It will tell me that the server can't be reached. This happens not only with my browser but with everything (Edge, Steam, Epic games launcher, windows update, etc). Trying to ping an address (IP or website) will sometimes work and other times fail. I have not noticed if there is a certain period of time in between when this happens. It already caused problems when trying to install windows updates. Had to reinstall because of it.
    I have tried several things to see if they fix/help my problem.
    I've tried:
    Putting in a PCIE network card.
    Changing DNS provider (OpenDNS)
    Tried different drivers (Asus and Intel)
    Reinstall Windows (Twice)
    Tried different ports on router.
    Tested Ethernet cable with second computer(Old laptop and had no issues with surfing internet)
    Uninstalled AV (ESET IS)
    Updated Bios (I'm not running the latest because the latest just relates to W11)
    I don't think I'm forgetting anything.
    I'm at a loss for what is causing this. I bought this Mobo last year. Thought I would get more than a year out of it. This issue is almost making me feel like my computer is unusable. I haven't noticed any other issues other than the networking issue. I appreciate any help. Thank you.
    ROG Guru: Brown Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 11 64bit Pro
    Network RouterPfSence Intel i5-10210U 6 Port
    Accessory #1 TP-Link Gigabit 8&6 Port Switches
    Apr 2018
    65
    1,238
    I don't think this is an issue with the onboard NIC or your mobo. Software is a maybe.
    Try a new network cable.
    Does not fix the problem, explain your network setup.
    Is the openDNS server near to you, 1.1.1.1 1.0.0.1 cloudflare might be another to try.
    Sound CardOnboard
    Sep 2021
    5
    Could it be the router?
    I will try a new cable as soon as I can.
    My network setup is nothing big. It's just a Netgear R6400 router with a Roku, my PC, my 360 and a Blu ray player hooked up to it via Ethernet. The cable for my PC is probably a 50 or 75ft cable because it is 2 rooms away from the router. I will try moving my PC out to the router and use one of the cables from one of the other devices to check if it is the cable.
    I hope it's the cable because anything I connect to the router via WiFi have no problems whatsoever.
    As far as I know the nearest OpenDNS server is in Chicago and I'm in northern Indiana. I will try cloudflare if the cable is ok.
    Sound CardOnboard
    Sep 2021
    5
    Tried a new cable and it didn't work. The new cable I used was brand new. I even tried it on a different port on the router too and no change. What now? Could it be the router or the mobo? WiFi devices still have no problems.
    Sound CardOnboard
    Sep 2021
    5
    Anybody got any ideas?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    344
    8,034
    You tried a separate network card and that failed too so I don't think it's your motherboard. Any chance that old laptop is 10/100 rather than gigabit? Could be the router is choking on ethernet connections in gigabit mode for some reason.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
  7. #7
    Sound CardOnboard
    Sep 2021
    5
    The laptop (Lenovo G550) is 10/100. I've found out a few things since I posted this thread. After doing various testing thanks to help I got from a user on a different forum, my router doesn't seem to be causing this issue. I've tested the hardware of my computer with a live usb of Linux Mint and the problem disappears. That tells me it's a windows issue because the problem disappears. I haven't had the time yet to dive into the depths of windows to try and find what is causing the problem.
