Results 1 to 4 of 4
    New ROGer Array screaminbrod PC Specs
    MotherboardASUS ROG STRIX X570-F
    ProcessorAMD RYZEN 5 3600
    Graphics Card #1INNO3D NVIDIA RTX 2070
    CasePHANTEKS P500A
    Power SupplyGIGABYTE 1000W
    Keyboard LOGITECH MK235
    Mouse LOGITECH M170
    Headset LOGITECH G733
    Mouse Pad Generic
    Headset/Speakers LOGITECH Z506
    OS WINDOWS 11
    Network RouterGOOGLE WIFI
    Nov 2020
    2
    ROG AURA TERMINAL LED Blinking fast
    I hope you could help me. I bought this Terminal just this year. it works well but all of a sudden all rgb connected to it won't light up. I thought it was just a software issue. After reinstalling the software and doing multiple reboots, nothing worked. Until i noticed that the LED on the terminal just blinks fast after a split second when it turns on.
    It is installed inside the Case using the molex and usb 9-pin connection. i have tried installing it as well outside the case using the power adapter and the usb cable type A that came with it. it won't still work and it still exhibits the same problem, (LED blinks fast).
    Thanks in advance for your usual help and support.
    ROG Guru: Orange Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)ASUS G752VL-DH71
    MotherboardROG Maximus XII Formula
    ProcessorI7-10700K
    Memory (part number)G-Skill F4-3600C19Q-32GTZRB
    Graphics Card #1ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    Graphics Card #2ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    MonitorLG UltraGear 32GN50T-B
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK PE 360 (Top), PE 240 (Front), and Xres 100 Elite
    CaseROG Strix Helios
    Power SupplyThermalTake Toughpower 1200W
    Keyboard ROG Strix Scope RX
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Windows 11 Pro 21H2
    Network RouterGeneric
    Accessory #1 Corsair ML140 (4 ea), Corsair ML120 (3 ea)
    Accessory #2 ASUS External 16X BLU-RAY Writer
    Jan 2016
    31
    257
    Try using the built-in lighting effects. Do not connect the micro USB cable or USB 2.0 Type-A data cable. If it works, it might be a software conflict. If it does not work, it might be a shorted Aura Terminal. You can also try disconnecting your LED Strips and see if the ROG Logo stays a static (no blinking) color during built-in lighting effect. It might be a shorted LED Strip.
    CasePHANTEKS P500A
    Mouse LOGITECH M170
    Mouse Pad Generic
    OS WINDOWS 11
    Nov 2020
    2
    Quote Originally Posted by pndiode View Post
    Thanks for the advise. I have tried what you have shared. for a split second it does light up normally, but then it would still suddenly blink fast again. when i press the button on the terminal, it does seem to change its led color. but still won't operate properly. i pressed the button by holding it down for it to turn off, but it won't turn off and it would still blink fast.
    no RGB cables are connected by the way on the terminal and i am just using the power adapter that came with it. i am still getting the same issue.
    pndiode PC Specs
    ProcessorI7-10700K
    Mouse Pad Generic
    Jan 2016
    31
    257
    I am out of ideas. Well its not a software conflict. Its not a shorted LED. It might be a defective Aura Terminal due to not working correctly using the built-in lighting effect. The ROG Logo should not be blinking (split second) using the built-in lighting effect. Try contacting ASUS Support to see what they have to say, since you brought it this year. Get a copy of your purchase receipt since warranty starts from date of purchase.
Tags for this Thread
