Page 9 of 14 FirstFirst ... 7 8 9 10 11 ... LastLast
Results 81 to 90 of 133
  1. #81
    ROG Enthusiast Array
    Dec 2014
    5
    71
    Quote Originally Posted by iisd View Post
    If you want to know more about sound delay (which weirdly is ignored a lot), watch this:
    https://www.youtube.com/watch?v=JTuZvRF-OgE
    It also shows a way to measure sound delay.
    I am divided myself on this. USB does have higher latency, but it also has pretty much no interference. Even when you turn the volume to the max you cant hear anything.
    Normal onboard chips have a much better latency, but also are very noisy, even on very expensive boards.
    ASUS PCI-E sound card from this video might be not the best example in terms of delay by the way. I don't know how about ASUS Essense STX II from the video but I had ASUS ROG Phoebus once. This is the card with greatest delay. The higher sampling rate = greatest delay. It was really, I mean REALLY noticeable.
    Back to video: my point is - other PCI-E sound card might have a better results.
  2. #82
    New ROGer Array
    May 2021
    57
    Hold up, coudn't asus just test all this using the exact same method as posted in this video? This be a lot more accurate than my jank phone and speakers...
  3. #83
    Moderator Array
    Apr 2019
    23
    780
    Hi Nuckels,
    Because the delay is slight, could you please help record a video in the specific games and play a video you mentioned, and our tech team can compare the difference.
    Please also provide me the information like the name and the version of the games, the browser and windows media player, youtube video link and wav. file you show in videos.
  4. #84
    New ROGer Array
    May 2021
    57
    Quote Originally Posted by STARRAIN@ROG View Post
    Hi Nuckels,
    I tried, the lag is too subtle to grab via a phone camera and speakers. You need to test it properly like here: https://www.youtube.com/watch?v=JTuZvRF-OgE something Asus HQ probably is way better of achieving than me. The audio is delayed nomatter what you do, removing enhancements helps a ton but it's still slower than on my asus z78-Pro 4770k setup. It doesn't matter what you do.
    I can record the wake up delay but it be identical to the previous videos I sent you in DM's already.
  5. #85
    Moderator Array
    Apr 2019
    23
    780
    Hi Nuckels,
    Our tech team had checked the wake up delay video you provided and it is normal.
    I'm not sure if the delay in games is lighter than the wake up delay, so it cannot be grabbed via a phone camera and speakers.
    I'm afraid without the video on your own, we have no idea how is the delay on your pc and your scenario.
  6. #86
    New ROGer Array
    May 2021
    57
    Hi Nuckels,
    I find it hard to believe the wake up delay is normal, it's not minor. I could plug in a usb device and hear NOTHING because the audio is over before it wakes up. Is that really normal?
    I can't make a video of the delay within games, it's incredibly subtle were talking in the millie-seconds here. Tell HQ to grab a game called "Osu" and try and play it. It's a rithm game and anyone with remotely decent reaction speed will instantly notice it.
  7. #87
    ROG Member Array
    Sep 2017
    21
    I am having the exact same issue with the ALC8082 codec on my Z690 Hero board.
    The most reliable way to reproduce the issue is to use the Windows sound output device "test" button, which plays a test tone on each channel sequentially. As long as no other audio is playing, some 25-50% of the time you'll hear the first tone (left) play, and then the second tone (right) will be missing the first 0.5s.
    In normal usage, this is also apparent when short notification sounds are played. For example, sometimes almost the entire Discord message notification sound will be missed, sometimes the second half of it will play.
    Following some forum diving, a workaround that's currently working for me is to enable listen to this device against Stereo Mix, and then set its volume to 0. The explanation offered is that this keeps the audio hardware awake, preventing the delayed wake-up issues. Doing this, the "test" button now works correctly, and I no longer have issues with notification sounds.
    I'm very disappointed that such an expensive board has issues even a $2 USB sound card doesn't, and that it's apparently been an issue for so many months (years?) with still no permanent fix in sight. Worse, that it apparently affected the previous generation of boards and was not addressed in that time.
    My current audio driver version is 6.3.9600.2297, the latest available on the support site at https://rog.asus.com/motherboards/ro...pdesk_download.
  8. #88
    ROG Member Array
    Sep 2017
    21
    Here's a video of the test: https://www.youtube.com/watch?v=YuWOuM19oFM
    Test 1: shows the issue
    Test 2: apply the stereo mix listen workaround, issue no longer occurs
    Test 3: remove the workaround, shows the issue again
    Also can confirm that none of the BIOS versions 0237 (original), 0702, nor 0803 (newest) have any effect.
    E: Can also confirm that driver version 6.3.9600.2306 from MoKiChU's package did not have any effect either. The problem remains the same as shown in the video linked here.
  9. #89
    Moderator Array
    Apr 2019
    23
    780
    Hi Nuckels,
    Our tech team will keep communicating with Realtek for new audio driver to improve audio performance.
    However, if there is no video in gaming to compare, I'm not sure if the improvement would meet your expectations.
    It might be another way to use the external sound card.
    Sorry for any inconvenience caused.
  10. #90
    Moderator Array
    Apr 2019
    23
    780
    Hi BobVul,
    Could you please help to create a new thread for the discussion about Z690 Hero board?
