Results 1 to 9 of 9
    ROG Guru: Yellow Belt Array Zeroed85 PC Specs
    Zeroed85 PC Specs
    MotherboardAsus Maximus XIII Hero - Z590
    ProcessorIntel i9 10900K - custom cooled
    Memory (part number)Dominator Platinum RGB 32GB 3866Mhz tuned
    Graphics Card #1ROG Strix 3080 OC - watercooled
    Sound CardSoundBlaster X AE-5
    MonitorAsus ROG PG349Q 34" 3440x1440 120hz G-Sync
    Storage #1Samsung 980 Pro 500GB, 860 Evo x 2,
    Storage #2Adata SX8200 Pro 1TB
    CPU CoolerCustom loop, EK PE 360, Corsair XR5 280 rads
    CasePhanteks Eclipse P600S
    Power SupplySeasonic Prime Ultra Platinum 1300W
    Keyboard Corsair K70 MK.2 SE
    Mouse Corsair Dark Core Pro wireless
    Headset Hifiman HE400i
    OS Win 11
    Accessory #1 Corsair Nexus
    Jun 2017
    207
    Question Strix 3080 OC - Coil whine
    I have terribly loud coil whine/buzz from my Strix 3080 OC. I have the card installed to an EKWB waterblock which makes the noise even more so unpleasant. I know that Asus implemented a noise mitigation feature into some of the Z590 motherboards to mitigate coil whine from the VRM and I wonder if the same noise mitigation could be implemented into a VBIOS for Strix GPU's?
    ROG Enthusiast Array
    Jun 2021
    59
    my Strix 3080 Ti OC luckily has 0 coil whine, even when the card is drawing 300+ FPS. My friends Strix 3070 Ti OC who I build a PC for just recently is the same. It might not even be caused by the GPU itself, but by the combination of PSU and GPU, since ASUS seems to be doing really well when it comes to coilwhine in the recent years. Do you have the chance to test the GPU with a different PSU?
    Btw I don't think you can get rid of coil-whine with an SW-fix
    I was built in 85 too
    Zeroed85 PC Specs
    OS Win 11
    Jun 2017
    207
    Quote Originally Posted by kubr0 View Post
    I do have a spare PSU but I suspect it would be a pain to swap it out. My main PSU is a Seasonic Prime Platinum 1300W. Asus did bake Noise Mitigation into one of the later BIOS's on the XIII Hero so maybe it is possible?
    Jun 2021
    59
    Coil-whine is HW-based, I don't think that a SW solution is going to make any difference there. Even if they are marketing such a feature, its weight is definitely going to be on the HW side. If the whine on the GPU is being caused by the mobo or PSU, no SW-fix is going to help that ...
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    190
    2,425
    1) PSUs produce their own coil whine. How much depends on the quality, type, specs, and size of the components used.
    2) The graphics card also produces some coil whine. Again, how much depends on the quality, type, specs, and size of the components used.
    3) Interaction between the PSU and graphics card can result in louder coil whine.
    4) Coil whine is related to frequency and current.
    5) Rapid changes in current demands (such as rapid load modulation when transitioning from low power state) is a major contributor to piezoelectric noise (some capacitor types are more prone to this).
    6) As ripple frequency and other sources of power related noise can impact the level of coil whine, some combinations of psu and graphics cards may exhibit more noise than others. For a vendor, it is very difficult to account for all permutations because cost is a factor if you want to increase resilience to coil whine. There is only so much a vendor will or can do.
    7) As current plays a part, the amount of audible whine will vary from system to system.
    Zeroed85 PC Specs
    OS Win 11
    Jun 2017
    207
    Quote Originally Posted by Silent Scone@ROG View Post
    Thanks for the detailed response. Are there any recommendations you can make to try to lessen or even eliminate the coil whine?
  7. #7
    Zeroed85 PC Specs
    OS Win 11
    Jun 2017
    207
    This is unfortunately the amount of coil whine I have from my Strix 3080 OC. It's pretty bad. It would be so nice to get rid of it.
    https://youtu.be/ndm03zRqQos
  8. #8
    ROG Guru: White Belt Array
    Jun 2014
    22
    85
    You can undervolt the GPU which will reduce Coildwhine a lot!
    Other then that, there is no way (beside changing the card).
    I had 2 RTX 3080 Strix with massiv coilwhine and returned both od that reason.
    Now i got the 3. (and last) Card, and this card has very much lower coilwhine.
    The first 2 cards, i can hear the coilwhine clearly from 60 FPS+
    The 3 card, i start hearing it at 150FPS+ and it is by far not that loud as the old cards.
    This is lottery, and it is not related to a manufacturer!
    But i payed 1300 Euro for the card, i therfor it has to be perfect...
    DO NOT OVERVOLT THE CARD, THIS MAY DAMAGE IT!
    I am not responsable for any damaged you did to the card!
    I would:
    Try to undervolt the card! This is something that i would do even if there was no coilwhine.
    You get much better temps, lower fan-noise and if done right, the same (or better) performance.
    Save starting point for testing (THIS IS NOT THE OPTIMUM, only a starting point to test coil-whine-results):
    850mV with 1800Mhz
    This should do every RTX3080 easy and you can check if coilwhine is better then.
    If not, return the card.
    If yes, find the best UV-Setting (900mV with 1900Mhz) for example!
  9. #9
    Mar 2016
    190
    2,425
    Quote Originally Posted by Zeroed85 View Post
    Given the above, the only real recommendation is to use a reputable power supply brand. These things are the byproduct of natural phenomenon in the world of electronics that's mostly outside of ones control, including vendors. There are far too many combinations of components to account for each scenario.
