Hi, everybody! Alex here!
I'm a proud owner of a ROG Zephyrus s17, which i personally use as an alternative mobile gaming/workstation setup since i moved temporary in Duesseldorf.
While what concerns gaming works flawless and gives me nothing to complain about, i'm experiencing a very frustrating issue with myASUS application.
It would be nice to have an integrated "asus" way to control battery level limits, but myASUS simply never worked.
I launch it and loads with normal animation, then turns in a white window, which is completely useless. I've tried virtually everything to fix it, performing reinstallations with registry cleaning and so on.
No matter which version of asus interface i have (V3 currently), it simply stays white despite of everything i tried. Up to date i haven't found a solution on the web describing my issue. There's apparently only one guy on reddit, which posted a screenshot of my exact problem but none found a solution.
Does anyone know a solution to this or has anybody experienced the same issue? Any workaround?
