Results 1 to 10 of 10
    ROG Guru: White Belt Array JuSiZ1 PC Specs
    JuSiZ1 PC Specs
    MotherboardRampage VI Extreme Omega
    Processori9-10940X
    Memory (part number)G.skill F4-3600C16Q-32GTZ
    Graphics Card #1EVGA RTX 3080Ti FTW3
    Sound CardCreative soundblaster X7 Le
    MonitorPG27AQ
    Storage #1Samsung 970pro 512Gb, Samsung 960 Pro 2Tb
    Storage #2960pro 1Tb 2x850pro 512gb and 1x1Tb 950Pro 512gb usbstick
    CPU CoolerEK Supremacy evo x99
    CaseDiy case
    Power SupplyCorsair Ax1200i
    Keyboard Logitech G19
    Mouse Logitech G
    Headset Fostex TH-610
    Mouse Pad ROG from china
    Headset/Speakers The Drop And Monitors speakers
    OS Win 10 Pro 64-bit
    Network RouterFritz Box 6490
    Accessory #1 H2O cooling with 3x360 rads, dual ddc pumps,EK blocks, 2x Aquaero 6etc.
    Accessory #2 BD-RE
    JuSiZ1's Avatar
    Nov 2014
    22
    99
    Angry Rampage VI Extreme Omega Serious Bios problem.
    I can,t figure out what is problem on newer than 3105 bioses.
    Newer bioses only works with default settings. If i put example 2400mhz mem oc system stops qcode BD or only put XMP on stops BD. Systems working on 3105 bios without any problem.
    Theres what i test this far:
    What working is Bios 3105 with ME v.11.12.82.1838
    Tested Bios 3201 , 3301, 3403 and 3501 works only default settings. if putting memory settings only example 2400mhz others auto/default stops qcode BD or if put only XMP on stops qcode BD. Those work on bios 3105.
    Someone in win raid forum mod bios 3501 with newer uCode not working and mod bios 3501 with bios 3105 uCode Not working.
    And of course tested with manual voltages/timings/everything.
    My system main parts.
    R6EO
    i9-10940X
    g.skill F4-3600C16Q-32GTZR
    Evga 3080Ti FTW3
    ROG Guru: Yellow Belt Array cekeu PC Specs
    cekeu PC Specs
    MotherboardROG Rampage VI Extreme Encore
    ProcessorIntel Core i9-10920X
    Graphics Card #1ROG STRIX GeForce RTX 3080 Ti
    MonitorASUS ROG SWIFT PG27UQ
    Power SupplySEASONIC PRIME 1300 W PLATINUM
    Keyboard ROG Falchion
    Mouse ROG Chakram Core
    Jun 2013
    36
    216
    It has happened in the past with the R6E. Stay with the working bios and forget about this "update" The most important thing is to be healthy.
    JuSiZ1 PC Specs
    Processori9-10940X
    MonitorPG27AQ
    CaseDiy case
    Mouse Logitech G
    Accessory #2 BD-RE
    JuSiZ1's Avatar
    Nov 2014
    22
    99
    Quote Originally Posted by cekeu View Post
    Thats right but no REBar support. This is annoing because over 700€ motherboard and basic things doesn't work. If anyone from ASUS can't fix this i think this is last asus motherboard to me. In first place, quality of this board not convincing me because when i bought this i got two DOA boards. third board what come from RMA was fully functional before this bios problem.
    ROG Member Array
    Mar 2012
    22
    Strange, mine is working fine with last bios and 64 GB (8X8) Gskill 3600. I've updated all times that new bios was released and every time worked. I can't figure out what is the problem.
    JuSiZ1 PC Specs
    Processori9-10940X
    MonitorPG27AQ
    CaseDiy case
    Mouse Logitech G
    Accessory #2 BD-RE
    JuSiZ1's Avatar
    Nov 2014
    22
    99
    Quote Originally Posted by MarcioTB View Post
    What processor you have?
    ROG Guru: Green Belt Array
    Feb 2019
    128
    598
    Look in the Modded BIOS section.
  7. #7
    ROG Guru: Green Belt Array restsugavan PC Specs
    MotherboardRAMPAGE VI EXTREME BIOS 3501 MOD
    ProcessorIntel Core i9 7980XE 2.60GHz
    Memory (part number)64GB GSKILL 3.2 GHz 16-16-18-36 2T
    Graphics Card #1ASUS ROG POSEIDON 1080Ti
    MonitorSAMSUNG ODESSEY G9 NEO 49 Firmware 1005.1
    Storage #1SAMSUNG 970 EVO PLUS 1TB x 3
    Storage #2WD 4TB External HDD
    CPU CoolerNZXT KRAKEN 62
    CaseCorsair Carbine 540
    Power SupplyCorsair AX1200i
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Headset/Speakers Sony
    OS Windows 11 Insider Preview 22478.1000
    Network RouterD-LINK
    restsugavan's Avatar
    Sep 2017
    92
    736
    Cascade Lake X had some issues from security vulnerable report. It require recently microcode to fixing checking lastest @Tistou77 modded BIOS on MODDED BIOS section.
    Windows 11 22H1 Build 22478.1000 Core i9 7980XE 02006COA MCU 2021-06-16 R6E 3501 MODDED BIOS TPM 2.0 Enabled VROC 7.6.0.1023 + RST 18.31.1.5256 ME FW 11.12.86.1877 DV 2124.100.0.1096 64GB DDR4 3200 XMP POSEIDON 1080i GTX NVIDIA Driver 510.10 WHQL 3TB SAMSUNG 970 EVO PLUS OMS Driver 18.36.3.1019 WHQL i219 V OROM 0.1.00 BA 0.1.16 12.19.1.37 WHQL AQC 107N FW 3.1.121 AQC 3.1.3.0 WHQL Realtek HD 6.0.9238.1 WHQL SAMSUNG ODYSSEY G9 49 NEO FW 1006 VESA HDR 2000 DP
  8. #8
    JuSiZ1 PC Specs
    Processori9-10940X
    MonitorPG27AQ
    CaseDiy case
    Mouse Logitech G
    Accessory #2 BD-RE
    JuSiZ1's Avatar
    Nov 2014
    22
    99
    Quote Originally Posted by restsugavan View Post
    Ok, i see those modded bios section but not found any modded OMEGA rebar bioses.
  9. #9
    ROG Member Array
    Mar 2012
    22
    Quote Originally Posted by JuSiZ1 View Post
    7920x
  10. #10
    ROG Guru: Yellow Belt Array MirceaForce PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel® Core i9-7920X Processor Extreme Edition 4.2 GHZ auto
    Memory (part number)G.SKILL 32GB 14-14-14-34 [Trident Z RGB] F4-3200C14Q-32GTZR
    Graphics Card #1NVIDIA GEFORCE GTX 1070 Founders Edition
    Graphics Card #2Samsung SSD 850 EVO 2TB
    Graphics Card #3Samsung SSD 850 PRO 2TB
    Sound CardSound Blaster Z
    MonitorIPS LED LG 27" 27UD69P 27 inch 4K 5 ms WhiteFreeSync - disabled, Display port
    Storage #1Samsung 950 PRO M.2 512GB OS
    Storage #2Samsung SSD 850 EVO 2TB
    CPU CoolerCORSAIR Hydro Series H80i v2
    CaseCooler Master: HAF X
    Power SupplySeasonic PRIME Titanium 850w
    Keyboard normal usb benq
    Mouse Razer Taipan
    Headset/Speakers Logitech Z-5500 digital
    OS Windows 10 x64 Pro up to date
    Network Router:Intel® Ethernet Server Adapter I210
    Accessory #1 LG OLED55C8PLA
    MirceaForce's Avatar
    Oct 2016
    8
    216
    7920x
    I have this cpu I9 7920x also and Rampage Extreme Omega and the latest bios & Intel ME from asus website and no issues here ...did you perorm a clear cmos with power down (remove from outlet) ? of course this should be done after each bios upgrade
    MB: ASUS RAMPAGE VI EXTREME-CPU: Intel Core i9-7920X Processor Extreme Edition 4.2 GHZ auto-CORSAIR Hydro Series H80i v2 Video: GEFORCE GTX 1070 Founders Edition. - G.SKILL 32GB 14-14-14-34 [Trident Z RGB] F4-3200C14Q-32GTZR- Seasonic PRIME Titanium 850 w-SSD: Samsung SSD 850 PRO 2TB x3 -SSD: Samsung 950 PRO M.2 512GB OS-Sound Blaster Z -Intel Ethernet Server Adapter I210 CASE:Cooler Master: HAF X MONITOR:IPS LED LG 27" 27UD69P 27 inch 4K 5 ms TV: LG OLED55C8P OS: Windows 10 x64 Pro up to date
