Results 1 to 2 of 2
09-17-2021 08:17 AM #1
- Join Date
- Feb 2021
- Reputation
- 10
- Posts
- 2
Gtx 980ti Matrix platinum safe mode
Greetings to all. Help to solve the problem :
I purchased a gtx 980ti matrix platinum on seals in a completely technically sound condition. And I would like to reset the bios via safe mode.
And so, I turn on the computer with the safe mode button pressed.
When I log into Windows 10, a pop-up window from GPUTweak appears saying something like "do you want to reset your GPU, it may take a few minutes", but before I can do anything, the pop-up window closes and nothing happens.
If I open the GPU setup manually, I get the same message, but it closes again before anything happens.
This happens both with the default bios and with the switched ln2 bios.
Is this a bug in Windows 10, does anyone know, or am I missing something, or can I try to make it work?
10-01-2021 12:09 PM #2
ThrashZone PC Specs Motherboard z490 XII Apex 2nd x299 VI Apex 3rd x99 sabertooth Processor i9-10900k w/Foundation & i9-9940x w/SigV2 & 5930k w/ek-Magnitude Memory (part number) Trident-Z 3600c16 2x8 2nd Trident-Z 3600C16 4x8 3rd 3200c14 4x8 Graphics Card #1 Titan Xp & 1080ti FTW3 both water cooled & evga 980ti gaming on air Monitor AOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz Storage #1 2-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games Storage #2 2-LG Blu-Ray WH16NS40 CPU Cooler 2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads Case 2- Corsair 450D with second floors for 240GTX & 280GTX rads & 2 Test Benchs Power Supply EVGA 1000P2 & 1200P2 & 850p2 Keyboard 3x Logitech G710+ Mouse 3x Red dragon Perdition OS Linux-Cinnimon 20.2 & Win-7-10-11 pro Accessory #1 Optimus Foundation copper plexi 2nd Optimus SigV2 Accessory #2 Mayhems clear all Accessory #3 ModMyMods 3/8-5/8" clear soft tubing/ MORA 360 Pro x2
- Join Date
- Oct 2017
- Reputation
- 30
- Posts
- 422
nvFlash ?
https://www.techpowerup.com/download/nvidia-nvflash/
Just proceed on with reflashing vbios doubt there is a reset
You will need the original vbios for the card you can usually find vbios on techpowerup data base
https://www.techpowerup.com/vgabios/
