Results 1 to 8 of 8
    ROG Enthusiast Array
    Jun 2011
    15
    49
    ProArt X570-CREATOR WIFI - No QVL Memory Listed for 5000 Series?
    Just got this MB today, and looking at the support site, it only shows 2000 and 3000 series APU in the dropdown. I have a 5950x that I'm putting in, and have learned the hard way to always do qvl...
    https://www.asus.com/Motherboards-Co...sk_QVL_Memory/
    Am I missing something?
    I have sent a msg to Asus support, and will post the answer here when I get it, just thought I'd ask here too just in case there is a x570 standard or something. Been a while since I did my last build, and wanted to check here.
    I like ROG :-)
    ROG Guru: Brown Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 11 64bit Pro
    Network RouterPfSence Intel i5-10210U 6 Port
    Accessory #1 TP-Link Gigabit 8&6 Port Switches
    Apr 2018
    65
    1,254
    For the RAM there are three QVL lists.
    Motherboard Manufacturer
    AMD https://www.amd.com/en/products/ryzen-compatible-memory
    Ram Manufacturer
    Suggest g.skill neo branded (work on all Ryzen)
    One is bare minmium, two out three aint bad (like a bat out of hell lol), and all three is overkill.
    Jun 2011
    15
    49
    Quote Originally Posted by RedSector73 View Post
    Ram Manufacturer
    Wow, Thank You RedSector73,
    A lightbulb just switched on!, I've always been focused on the MB qvl. I'm sitting here thinking, got most my parts and I have to wait for an updated list......
    I did a lot of Rampage Builds years ago, this one will be fun too. Appreciate the help!
    Best regards,
    I like ROG :-)
    Apr 2018
    65
    1,254
    It's nice MB, post some pics when you are done
    DDR4@3600 CL16 Dual Rank (DR)x2 or Single Rank (SR)x4 would be speed recommendation vs cost or if money no object ... what I have DDR4@3800 CL14 or even DDR4@4000 is also a top of the top option (for Ryzen 5000 series).
    Jun 2011
    15
    49
    Thanks for additional reminder on 1 and 2T. Ya, money an object, problem is, building a machine is an exception! Just so I have it right, stick to 2 sticks if 2T, and fine with 4 sticks if 1T?
    I fiddle with PowerDirector/Cyberlink for vid editing, and was leaning 32gb. If doing 4 sticks, still have to buy a 4 stick packet, correct?
    I have a 2080ti still in the box, and waitlisted for a 3080 or ti.... so at least I can get started with the 2080
    And yes, when done I'll post a pic
    I appreciate your guidance, I honestly didn't focus too much on memory in the past (don't know much), as doing 3 x sli, was more focused on the gpu's, 3 x surround, NV 3d... I always had problems when I maxed out the cpu and gpu's and started messing with memory.
    Here's a pic of an old 680 on a Rampage that pulled some amps Kinda funny just having 1 card now.
    I like ROG :-)
    Apr 2018
    65
    1,254
    Quote Originally Posted by djb View Post
    Here try these two videos
    https://www.youtube.com/watch?v=-UkGu6A-6sQ
    1t is always best but isnt what I was referring to.
    Looking great your system
  7. #7
    Jun 2011
    15
    49
    Thank you for your help, got it, and truly appreciate it
    I like ROG :-)
  8. #8
    Jun 2011
    15
    49
    Posting Asus support response as I said:
    "All the RAM are compatible as long as it is included to the QVL."
    But they don't have anything listed above 3200. So, got as you recommended to begin with, GSkill "neo", 3600 CL16, SS. Ended up with 4x8gb. Backordered, but good price and from NewEgg. Made sure it was on Ryzen QVL site though too, thanks for that "lightbulb". Onward.
    Thank You for the info and tips.
    I like ROG :-)
