Results 1 to 7 of 7
09-20-2021 09:13 AM #1
- Join Date
- Jan 2016
- Reputation
- 10
- Posts
- 4
Asus RT-AX88U problems with lost connection
I bought Asus RT-AX88U router (Firmware Version:3.0.0.4.386_45375) a few weeks ago and it is constantly dropping my internet connection. Multiple times per day I get connection lost on all devices connected to router through WiFi or with cable (it is very noticeable in online games where I get connection lost from server). I don't know what could be causing this, in my System general log every 10 seconds a few lines are displayed, I am not sure if this is normal or this could be the problem which is causing connection losts:
Sep 20 11:10:19 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 00:1D:63:29:99:49, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Sep 20 11:10:19 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 00:1D:63:29:99:49, status: 0, reason: Unspecified reason (1), rssi:0
Sep 20 11:10:19 wlceventd: wlceventd_proc_event(527): eth6: Auth 00:1D:63:29:99:49, status: Successful (0), rssi:0
Sep 20 11:10:19 wlceventd: wlceventd_proc_event(556): eth6: Assoc 00:1D:63:29:99:49, status: Successful (0), rssi:-52
Sep 20 11:10:23 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 00:1D:63:29:99:49, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Sep 20 11:10:23 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 00:1D:63:29:99:49, status: 0, reason: Unspecified reason (1), rssi:0
Sep 20 11:10:36 wlceventd: wlceventd_proc_event(527): eth6: Auth 00:1D:63:29:99:49, status: Successful (0), rssi:0
Sep 20 11:10:36 wlceventd: wlceventd_proc_event(556): eth6: Assoc 00:1D:63:29:99:49, status: Successful (0), rssi:-52
Sep 20 11:10:40 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 00:1D:63:29:99:49, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Sep 20 11:10:40 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 00:1D:63:29:99:49, status: 0, reason: Unspecified reason (1), rssi:0
Sep 20 11:10:40 wlceventd: wlceventd_proc_event(527): eth6: Auth 00:1D:63:29:99:49, status: Successful (0), rssi:0
Sep 20 11:10:40 wlceventd: wlceventd_proc_event(556): eth6: Assoc 00:1D:63:29:99:49, status: Successful (0), rssi:-52
Sep 20 11:10:44 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 00:1D:63:29:99:49, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Sep 20 11:10:44 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 00:1D:63:29:99:49, status: 0, reason: Unspecified reason (1), rssi:0
Sep 20 11:10:58 wlceventd: wlceventd_proc_event(527): eth6: Auth 00:1D:63:29:99:49, status: Successful (0), rssi:0
Sep 20 11:10:58 wlceventd: wlceventd_proc_event(556): eth6: Assoc 00:1D:63:29:99:49, status: Successful (0), rssi:-52
09-22-2021 09:10 AM #2
- Join Date
- Apr 2020
- Reputation
- 32
- Posts
- 87
Hi could you send a feedback to asus and PM me your email
Thanks.
09-28-2021 02:51 PM #3
- Join Date
- Aug 2014
- Reputation
- 10
- Posts
- 12
Latest firmware causes my nest camera’s to drop connection multiple times a day (Signal strength shows Great in the app they have ran perfectly for a year) sometimes they reconnect on their own other times a camera power cycle is required to reconnect.
Ran on the new firmware for about two weeks this was a problem the entire time, I have tried to power cycled AX88U tried factory reset does not fix it. i have now flashed previous firmware and back to working perfectly no more drops.Last edited by Republic of Pax; 09-30-2021 at 08:55 PM.
10-11-2021 07:18 AM #4
- Join Date
- Jan 2016
- Reputation
- 10
- Posts
- 4
I am so disappointed with this router that I can't believe it. From around 10 routers I owned so far in past 20 years (and all cheaper) this is one of the worst I had and based on price this is unacceptable. 5x cheaper router never disconnected / lost connection while this one does it multiple times per day for no reason (I have other PC connected directly to modem and it doesn't loose connection so I know it's 100% routers problem, not modem/ISP).
I also updated it yesterday to latest firmware and it's the same. Also sent feedback with this problem and no response or fix.
10-12-2021 10:01 AM #5
- Join Date
- Oct 2021
- Reputation
- 10
- Posts
- 1
I'm having exactly the same problem, but then with my GT-AX11000. Multiple Nest cams dropping out multiple times a day with same logs as @SilverSilencer.
10-29-2021 08:48 AM #6
- Join Date
- Jan 2016
- Reputation
- 10
- Posts
- 4
I got new router today (replaced) and I'll see if it will be any better.
01-10-2022 08:59 PM #7
- Join Date
- Sep 2010
- Reputation
- 10
- Posts
- 36
