Results 1 to 4 of 4
    ROG Guru: Yellow Belt Array Crasje's Avatar
    Aug 2013
    15
    158
    Xg349c - aura - usb
    I finally got my XG349C working after receiving a second monitor, which had the same issue as the first and it turned out my USB uplink cable was broken.
    However, now I am running into the following issue:
    After connecting the working USB uplink cable (and saw my monitor in armoury crate to sync AURA) I attached my Claymore to my monitor USB. Worked like a charm! Next time I started my PC my keyboard didn't work so I could not type my Windows password. I removed the keyboard USB and plugged it in on my PC. Gamed all day and never checked anything else.
    This morning I started my PC and noticed the AURA was not working. Opened armoury crate and my monitor was not visible. I moved the uplink cable USB ports around on my PC, heard the windows ping of new device et voila. Armoury crate saw the monitor again.
    Any suggestions on what I can do here? I have the feeling that the whole USB uplink functionality not very stable, this is 1100 euro monitor. I already have send one back, but it seems there is either a bad batch out there or I am extremely unlucky. I set my USB port to 'on during standby'.
    It seems a bit silly that I can't normally use an USB port or have to unplug - plug the uplink to get it working.
    Any suggestion anyone?
    Cooler Master Cosmos II (with glass side panel)
    Cooler Master Silent Pro Hybrid 1300W ATX
    ROG Asus Maximus IX Formula
    Intel Core i7-7700k
    Corsair Hydro Series H115i CPU Cooler
    Corsair Vengeance LED 32GB 3000Mhz
    Samsung 960 EVO 500GB NVME M.2 SSD
    Crucial SSD M500 480GB
    Seagate Firecuda 1TB
    Samsung SH-224DB (SATA, 24x)
    ROG RTX3080-O10G-Gaming
    Monitor 1: ROG STRIX XG349C
    Monitor 2: Samsung HDTV T27D590
    ROG Claymore
    ROG Spatha X
    ROG Balteus Qi
    Windows 10
    Aug 2013
    15
    158
    update, this morning it was stable... still not using the USB in the back... will try that next.
    Intel Core i7-7700k
    ROG Claymore
    ROG Spatha X
    ROG Balteus Qi
    Windows 10
    ROG Member Array JeffroMan PC Specs
    JeffroMan PC Specs
    MotherboardZ690 Maximus Hero
    Processori9-12900KF- Alder Lake
    Memory (part number)Corsair DDR5 CMT32GX5M2B5200C38
    Graphics Card #1Asus RTX 2060 OC Strix
    Sound CardIntegrated Audio
    MonitorAsus ROG XG349C
    Storage #1Samsung 1TB EVO 860 SSD
    Storage #2Samsung 1TB 980 Pro NVME 4.0 SSD
    CPU CoolerCorsair iCue H115i Elite Capellix
    CaseCorsair Carbide Series Air540
    Power SupplyEVGA 1200 P2 Platinum
    Keyboard ROG Strix Flare
    Mouse ROG Chakram Core
    Headset Corsair Virtuoso RGB Wireless XT T-Pain Edition
    Mouse Pad ROG gaming mat
    OS Windows 11 Home 64 bit
    Aug 2015
    18
    I have the same issue concerning the Aura sync function of this monitor. Every time when I boot up the computer, the monitor's Aura lighting does not function. When I launch Armory Crate the monitor does not appear as an Aura Sync device. I then turn off the monitor then turn it back on after a couple of seconds then it appears in Armory Crate and the Aura lighting of the monitor functions normally. This work around this issue works every time. Asus, please fix.
    ROG Guru: Green Belt Array
    Feb 2019
    129
    692
    My PG35VQ never worked from day one with synching lighting. I turned off the aura on the monitor and just leave it in a static color, not like I can see it anyhow, just a nice blue backlight and done. Shows up in armory crate but like everything else with that under developed app it doesnt work.
