Results 1 to 2 of 2
    New ROGer Array
    Oct 2018
    1
    Exclamation Urgent need help with M.2 Slots - ASUS ROG G703GX
    Hi everyone,
    I have an ASUS ROG G703GX with an Intel Core i9, and I have just purchased the Samsung 980 Pro 500GB.
    The problem is that I would like to know which slot is better to install this NVMe SSD drive to gain the performance speed.
    I have 3 M.2 Slots but I think 2 are CPU-Attached.
    Please refer to the picture attached.
    Thanks!
    ROG Guru: Blue Belt Array
    Nov 2012
    75
    795
    Here's a teardown video of the G703GX at the 1minute 50 the m.2 slots are described. The two on the right are direct connected to the CPU.
    https://www.youtube.com/watch?v=P23w...terUpgradeKing
    Good Luck
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
