Results 1 to 5 of 5
    New ROGer Array
    Sep 2021
    4
    GT-AX11000 Issue With Gaming Band
    Hey guys,
    I am fairly techy. I am an automation programmer for a living and do some python programming but I am not super familiar with networking and routers. The main reason I purchased this router was for my oculus quest 2. I have pretty much everything setup default for the router. When connecting to my 5g gaming band I have full signal but I have almost 0 internet access. Sometimes I can load a webpage and do a speedtest and ill have <1mb. On the regular 5g band and the 2.4 ghz band they work fine. I'm not sure exactly why this is. Does anyone have some suggestions? I live out in the county and my neighbors are quite far so I don't anticipate having any interference.
    THanks,
    Kevin
    ROG Guru: White Belt Array
    Apr 2020
    32
    84
    New ROGer Array
    Sep 2021
    4
    Thank you for the reply. I will give this a try tonight and get back to you.
    New ROGer Array
    Aug 2021
    47
    Quote Originally Posted by kevilay View Post
    Hey guys,
    THanks,
    Kevin
    Got the same and my Quest 2 connects at 1200mbps,or whatever it says.
    Personally found default firmware very buggy so am using a beta,works much much better for me.
    https://www.asuswebstorage.com/navig...78A44D97422DBY
    New ROGer Array
    Sep 2021
    4
    Quote Originally Posted by wilsondenq View Post
    With this enabled my 5g gaming band is now usable. Thank you. I will have to play some more with my quest and try that beta firmware out.
    Thanks,!
Tags for this Thread
