Results 1 to 3 of 3
10-01-2021 03:35 PM #1
- Join Date
- Sep 2021
- Reputation
- 10
- Posts
- 4
GT-AX11000 Recommendation For Wifi Extender
Hello Guys,
I have a gt-ax11000 router. I am currently running ethernet lines in my house to hardwire some important connections. I have run one out to my garage (out of wifi range by a fair bit). In my garage I want to create a wifi network so inside my garage I will have wifi. I have a couple old routers laying around. Not sure if I can convert one of them into an extender? How would I know? On another angle. Do you guys have a recommendation as to what I should connect up to the other end of the ethernet cable in my garage to broadcast the signal.
Thanks,
Kevin
10-08-2021 12:13 AM #2
- Join Date
- Sep 2020
- Reputation
- 10
- Posts
- 23
10-14-2021 03:35 PM #3
- Join Date
- Aug 2021
- Reputation
- 10
- Posts
- 75
Any router is fine as long as it can accept the ethernet cable as WAN,some isp 'routers' are modem routers
and that the router has wifi of course.
you should be able to configure it so the AX11000 takes care of all DHCP IP's in the garage or let the garage router have its separate own network.
The garage router is the 'extension' so thats all you need,no need for meshing.Last edited by Indigian; 10-14-2021 at 03:38 PM.
